i have trouble to get some favourites into the quickstart on top . I can add them, they work..but after restarting , they are gone..
Is there anything i do wrong or is it a bug ?
V 3.4 3973
regards 73
Harry DL9NDW
Problem with favourites in quickstart bar
Re: Problem with favourites in quickstart bar
Hi Harry,harrygeier wrote: Thu Sep 17, 2026 9:10 am Hi,
V 3.4 3973
regards 73
Harry DL9NDW
Sorry - can't be done - yet. As favourites are loaded dynamically from an XML file, this happens after the Quick Access Toolbar is created. I'll see if there's a workaround.
A timer at startup and a button press message when the timer runs out? It's kinda crude. It's how I've made some other you have to be booted in order to boot sort of problems.
harrygeier
At least no error on my side..
thanks for the answer anyway..
Harry
Harry
