So,
New kit here: viewtopic.php?f=63&t=369&p=1798#p1798. I'm thinking we have a bad structure on a disk, with luck this'll find the problem.
SDR Cvonsole crash playing recording
Re: SDR Cvonsole crash playing recording
Simon
I get this when I click on the link
You are not authorised to read this forum.
Regards Ian
Regards Ian
Try again, I just added you to the Test Team.
Simon
OK have access to page, tried 3.026 and the same crash
Please advise if you need me to provide any data, I will do my best
I see JDOW has experienced similar issues
i did try deleting the 2nd Airspy in the Select radio but it made no difference, you can actually select the wrong Airspy SDR receiver
I will standby for any developments or instructions.
Regards Ian G0FYD
Regards Ian G0FYD
OK,G1IZO wrote: Fri Oct 23, 2020 1:46 pm Simon
Regards Ian G0FYD
Please run DebugView and save the log after a crash, this shows me how far it gets.
Simon
Loaded up debugview and connected local
It captures all activities but when I crash console by hitting REC/PLAYBACK and open it records nothing
No data whatsoever.
I think im doing it ok as it records all of Console starting up and other activities
Regards Ian G0FYD
No data whatsoever.
Regards Ian G0FYD
Please - Please - Please: show me the output in DebugView - I want to see it, we'll take it from there. You can save DebugView output to a file and attach.
Simon
Attached but I think the crash produces no data
Regards Ian
Regards Ian
- DESKTOP-KD7K1TN.LOG
- (334 Bytes) Downloaded 206 times
- (334 Bytes) Downloaded 210 times
- (334 Bytes) Downloaded 209 times
OK, before I start the serious diagnostics, if the radio was running please stop the radio before selecting this option.
I'll add more diagnostics so we can trace this.
