Spectrum Scale
hl2
Spectrum Scale
Unread post by hl2 »
How can i change the dbm steps in Spectrum?
At the moment there are only 5db steps, i wwould like to change to 10db
Re: Spectrum Scale
I don't think there is an adjustment for that directly but can be achieved by manually setting high/low values for scale here (usually defaults to "auto"):
Re: Spectrum Scale
hl2 wrote: Tue Sep 07, 2021 11:42 am How can i change the dbm steps in Spectrum?
You can't, it's fixed as Max shows.
hl2
Re: Spectrum Scale
At Max s snapshot there are 10db steps.When i change the scale manually like Max, its still at 5db
Re: Spectrum Scale
hl2 wrote: Tue Sep 07, 2021 2:06 pm At Max s snapshot there are 10db steps.When i change the scale manually like Max, its still at 5db
Ah, that's probably a drawing algorithm.
Re: Spectrum Scale
Simon G4ELI wrote: Wed Sep 08, 2021 2:37 pm
Ah yes, I can see it changes as you click and drag the horizontal divider bar up and down between spectrum and waterfall.
