For my purposes, Kriss, 32-inch 1920x1080 is great for FM BC. It's the overall band status I need first, then activity in the "holes", then any abnormalities that suggest interesting propagation.KA1GJU wrote: Tue Jan 26, 2021 6:09 pm So you will need a bank of 4K monitors to actually see something of value with 10, 20, 30 MHz bandwidth?![]()
CloudSDR
Re: CloudSDR
Paul White (Grumpy Old Git)
Re: CloudSDR
I would use 4k at that size. I've seen Console running on 60" 8k monitors...
Re: CloudSDR
Is anyone running a CloudSDR with SDR Console? I cannot connect to mine and assume I have a setup problem.
Re: CloudSDR
Post the logfile as an attachment.WReeve wrote: Wed Jan 18, 2023 5:40 am Is anyone running a CloudSDR with SDR Console? I cannot connect to mine and assume I have a setup problem.
Re: CloudSDR
Sorry for the delay.
I've attached the logfile for a single attempt at connecting to a CloudSDR at 10.0.0.120:50112.
- SDR Console tmp.txt
- (2.27 KiB) Downloaded 640 times
Re: CloudSDR
Logfile attached for one connection attempt to a CloudSDR at 10.0.0.12:50112.
- (2.27 KiB) Downloaded 641 times
Re: CloudSDR
OK, what about firewalls? I assume your local net is 10.0.0.x?
Are you sure port 50112 is correct?
Re: CloudSDR
Yes, the application is allowed in the Windows Defender Firewall and, yes, the local net is 10.0.0.x, and, yes, the port 50112 is correct.
I use IP 10.0.0.120:50112 to connect to the radio using SpectraVue without problems.
Re: CloudSDR
Okay, problem solved. First, my router was handing out 10.0.0.120 to a Macbook Air, so I deleted that and reserved a new address 10.0.0.112 for the CloudSDR on port 50112.
Next, I had manually added the CloudSDR in SDR Console but that didn't work. I used the SDR Console Search function for RFSpace and it found both of my CloudSDR. I saved those and now can connect okay.
