Re: Frequency Database and RDS Log - SQLite comparison
Posted: Tue Aug 24, 2021 11:09 am
I knew that!G0OFE wrote: Fri Aug 20, 2021 3:50 pm
Need a new column with a formula - e.g A2/1000000 - it's what I did.
I aalso need to check I haven't accidentally got one lot of frequencies imported as text and ended up with a data type mismatch - it won't be the first time!
Incidentally you shouldn't need a new column, you could use a formula within the vlookup function
eg =vlookup((A1*10^-6);'table'A1:B100);1,0). That's the formula I use in another table where one set of frequency data is in Hz and the other set of data is MHz.
