Page 2 of 2
Re: ELad FDM Duo - Tuning from DX Commander one way?
Posted: Fri May 19, 2023 1:11 pm
by luigi
ippi ippi urraaaaa
it seems that everything works now. the problem was the incompatibility of VSPE with SDRC. I downloaded VSP manager and the sync works on both sides
only the last request, as you set:
Poll Int:?
Timeouts:?
Posted: Fri May 19, 2023 10:11 pm
luigi wrote: Fri May 19, 2023 1:11 pm ippi ippi urraaaaa
Poll Int:?
Timeouts:?
I have never changed them from the default values as far as I recall:
Posted: Sat May 20, 2023 5:28 pm
by luigi
what is the right VBAudio cable software you use?
send me the direct download link.
on VBAudio there are various software
Posted: Sat May 20, 2023 10:35 pm
luigi wrote: Sat May 20, 2023 5:28 pm what is the right VBAudio cable software you use?
I don't use VB Audio (but many do).
If you do need a virtual audio cable..........
VB-Audio, you need VB-Cable:
https://vb-audio.com/Cable/
I use VAC by Eugene Muzychenko:
https://vac.muzychenko.net/en/index.htm
Posted: Sun May 21, 2023 1:32 pm
by luigi
tnx.
wiht my flex all work s perfectly.
with SDRC work and sometimes not.
mysteries of computer science hi hi
Posted: Sun May 21, 2023 11:08 pm
luigi wrote: Sun May 21, 2023 1:32 pm tnx.
Reason I use VAC and not VB-Audio is that on my old PC, for some reason I could not get VB-Audio to work at all with SDRC, but VAC always worked perfectly. Now I have a new motherboard. VB-Audio seems to work fine with SDRC now, but other than to test it out, I have stayed with VAC and it always seems perfectly fine. As I've paid for it I just stay with VAC!
