Page 2 of 5
Re: SDR Starter problem
Posted: Sat Sep 26, 2020 7:27 am
by G4ZFQ
As the drop-down conceals the driver we cannot tell. Zadig can install one of 3 drivers.
Win USB is the normal one.
Also a check of Device manager will tell if there is a problem.
Alan
Posted: Sat Sep 26, 2020 9:02 am
by m3ghe
mbzadegan wrote: Fri Sep 25, 2020 8:24 pm
Thanks for your help
When I run zadig, the attachment screenshot is my current status.
Does it mean my driver installed correctly?
You have to use Zadig to replace the driver that was automatically installed by Windows.
It looks like you have only gone as far as letting Zadig tell you what devices are on the system.
Do it for both Bulk interface devices 0 & 1, they are both on the same RTL-SDR.
Posted: Sat Sep 26, 2020 6:31 pm
by mbzadegan
OK
I have reinstalled both of interfaces (0,1).
As shown in the attachment does RTL Dongle(TCP) is right?
Posted: Sun Sep 27, 2020 9:37 am
by m3ghe
mbzadegan wrote: Sat Sep 26, 2020 6:31 pm
OK
No it isn't right. Zadig installs the USB driver for the RTL-SDR. You have selected RTL Dongle(TCP).
If the dongle is connected to a USB port on the same PC as SDR Console then you should be selecting RTL Dongle(USB).
If you have the dongle connected to another computer, tell me now.
Posted: Sun Sep 27, 2020 6:41 pm
by mbzadegan
Thanks a lot.
Finally, I can run it with RTL Dongle(USB) without a problem.
I took a screenshot of my status.
Now, a beep noisy sound has been heard from the speaker.
How can find it is in FM modulation or AM modulation?
How can I switch it to AM 730 or Airplane communications?
Thanks again.
Posted: Mon Sep 28, 2020 7:24 am
by PD3LK
Posted: Mon Sep 28, 2020 10:42 pm
by mbzadegan
Thank you.
I have read
https://www.sdr-radio.com/receive-dsp but still, I don't know how can I set the receiver to AM 730 kHz?
I have attached my current status.
I don't know what is the meaning of 730.000.000. Is it 730 MHz or 730 kHz?
Also, Does my setting set to AM by the arrowed button?
Thanks again.
Posted: Tue Sep 29, 2020 7:32 am
by VK5HI
You are tuned to 730 MHz.
Regards. Colin VK5HI.
Posted: Wed Sep 30, 2020 3:03 am
by mbzadegan
Ok,
I have only noisy sound when I set it to AM 690 (CBC) or AM 730 (Vancouver Traffic) and I can not hear any vocal sound.
Do you know what is my problem?
Posted: Sat Oct 03, 2020 3:13 am
by mbzadegan
Any suggestion?
