Page 2 of 2
Re: 3.0.25 Random Crashes
Posted: Tue Oct 06, 2020 11:43 am
This I don't like:
- BadIFImage.jpg (12.88 KiB) Viewed 2570 times
Indicates to me that you're running out of graphics resources. Why not add a GPU, for example GTX 1050 Ti ? Any GPU will do.
Posted: Tue Oct 06, 2020 4:23 pm
by M0TGC
Is there a way to know what the use of graphics resources is? Would it help to stop using the IF spectrum display?
True I could add a GPU but I guess I'd need two for twin screens.
Posted: Tue Oct 06, 2020 5:45 pm
M0TGC wrote: Tue Oct 06, 2020 4:23 pm
Many, many GPUs support two or more displays.
Posted: Wed Oct 07, 2020 10:07 am
by G6PZZ
My Gigabyte 1650 Super is running two screens as i write this but my previous 7 year old Radeon did too.
Tom G6PZZ
Posted: Wed Oct 07, 2020 2:21 pm
G6PZZ wrote: Wed Oct 07, 2020 10:07 am
Tom G6PZZ
I have a GTX 750 on my office computer (uses every three months for filing tax information), drives a pair or Eizo LCD which cost a fortune ~15 years ago!
Posted: Wed Oct 14, 2020 10:27 am
by M0TGC
This has "crashed" again in that the display froze but the app was still running. However, I now have more info.
SDRC had been running for some time and the display froze when I switched on the power of the external radio. The radio is connected to the PC via a cat cable but was "off" in SDRC at the time. The log is attached together with screenshot and I also have a dmp file if required.
Last few lines of log:
08:38:20.186: Radio Reader> Sample rate: 1000110.233859
08:40:00.194: Radio Reader> Sample rate: 1000056.053142
08:41:40.183: Radio Reader> Sample rate: 1000104.218751
08:43:20.195: Radio Reader> Sample rate: 1000046.116127
08:49:19.641: OnSysCommand: nID 0000F120 SC_RESTORE, lParam 00000000
10:52:11.043: USB Notification: Device Unknown, A device has been added to or removed from the system.
10:52:11.118: USB Notification: Device Unknown, A device has been added to or removed from the system.
10:52:11.139: USB Notification: Device Unknown, A device has been added to or removed from the system.
Posted: Wed Oct 14, 2020 10:37 am
by M0TGC
Also, it left something in an odd state. I closed SDRC and restarted it and the radio failoed to start, the log showed:
11:31:43.120: Radio SDRplayV3: Connect> Opening API
11:31:43.120: Radio SDRplayV3: Connect> Error sdrplay_api_Fail
11:31:43.120: Select Radio> Status .....: Failed
I then closed SDRC and opened SDRuno which found the RSP1A. I then went back to SDRC and all then started normally.
Hope this helps.
Posted: Wed Oct 14, 2020 4:37 pm
This is the clue - USB power. You maybe heard the bingly-beep sound.
