Page 2 of 3
Re: Higher "Min elev" for satellite passes
Posted: Sun Apr 25, 2021 1:35 pm
by VE3HST
Since the Automatic Scheduler Minimum Elevation change to 80 degrees didn't happen in 3.0.27, I wonder if it is planned for the next release? The issue is described extensively in the preceding messages on this topic. To summarise, the Automatic Scheduler Minimum Elevation is the part that doesn't work. The Passes window (which is just what you see) seems to work but what is most important is the Automatic Scheduler itself which determines if a pass actually gets recorded or not. And now everything gets recorded regardless of the minimum elevation setting.
Posted: Sun Jun 06, 2021 1:00 pm
by VE3HST
Here is an updated explanation of the request to make the "Min. elevation" function work correctly for satellite passes. The "Min. elevation" that can be set was recently increased to 80 degrees. That is good. However, that unfortunately only affected what is displayed in the two windows "Schedule" and "Automatic Schedule". In the example (below), even though the "Min. elevation" is set at 20 degrees, SDR Console records all passes. The lower elevation pass is being recorded in the screenshot even though it is not shown in the two schedule windows. So, the windows work and display correctly, but the recording function currently ignores the window settings, and records all elevations.
Posted: Thu Jun 10, 2021 11:12 am
Finally - I'm looking at this now.
So, if the automatic schedule is on only recording when above the minimum elevation?
Posted: Fri Jun 11, 2021 12:20 am
by VE3HST
Not sure I understand the question.
Short summary.
The "Min elevation" should determine which passes get recorded.
However, all passes get recorded regardless of what is set (and shows) as "Min Elevation".
Posted: Fri Jun 11, 2021 6:44 am
VE3HST wrote: Fri Jun 11, 2021 12:20 am
Short summary.
OK,
Now if we have min elevation set to 30 degrees we record the whole of this pass? I'll check recording when there's an enabled schedule.
Posted: Fri Jun 11, 2021 11:42 am
From a position of relative ignorance for LEO satellite work, might it not be best to declare you want the satellite to reach at least X degrees above the horizon during its pass and you want the entire pass recorded?
{o.o} Me needs some education here.
Posted: Fri Jun 11, 2021 12:05 pm
jdow wrote: Fri Jun 11, 2021 11:42 am
This is indeed another option.
Posted: Fri Jun 11, 2021 1:20 pm
by VE3HST
Yes, it should record the whole pass for any pass that has a maximum elevation at or higher than the "Min elevation".
Any pass with a maximum elevation lower than the "Min elevation" should NOT be recorded.
In this way, you only record the passes that you assess as "good" and are of interest because they are higher than the "Min elevation" that you choose to set.
Posted: Fri Jun 11, 2021 1:57 pm
VE3HST wrote: Fri Jun 11, 2021 1:20 pm
Agreed.
Posted: Sat Jun 12, 2021 3:38 am
Now that I am awake, I do not see the difference. If its maximum is above a minimum it is at least above a minimum. I needed some wake up juice when I typed that message. And with disk space nearly free these days (compared to the $1k for 19 megabytes days or even the buck a gigabyte days) the whole pass should be recorded OR ELSE you need to provide a degree by degree shadow mask for obstructions and antenna pattern issues. That or else is a programming hum dinger and requires a lot of work on the part of the user to generate the shadow mask.
