Lime-Mini TX and SDR-Console V3.0.25
Re: Lime-Mini TX and SDR-Console V3.0.25
G4SDG wrote: Tue Oct 06, 2020 11:13 pm Hi all,
Is anyone else experiencing problems with the Lime-Mini transmit and SDR-Console v3.0.25 64bit? Mine will transmit once but then when I click on the "Transmit" button again nothing happens. The receive carries on functioning and I can see the microphone audio bar moving when I speak but there's no RF. I have to stop and restart the Lime on SDR-Console but then it again only transmits once. "Tone", "Tune" and SSB seem to act in the same manner. I've rolled back to 3.0.19 (unfortunately the last download version I have on file - when will I learn!) and that works OK. Before upgrading to v3.0.25 I had been happily running 3.0.23 but never upgraded to 3.0.24 is it apparently already had a known Lime transmit problem. I've checked the Lime's firmware and according to the latest version of LimeSuite it's showing FW:6 HW:2 Protocol:1 GW:1.28 with no conflict. My PC is an Intel 8th Gen NUC i7-8559U 2.7GHz with 32Gb.
Chris G4SDG
Just started on this, problem reproduced.
I think I have this solved, need a clear head tomorrow and Thursday to confirm.
Working on this - testing with Mini seems OK now, looking at a few other minor issues, then I'll test with the Lime USB. Expect a kit on Friday.
khut
Unread post by khut »
Subject:
Lime-Mini, SDR-Console V3.0.25 and ...looking at other issues:
please look at "Bandwidth 1.5MHz (tx)" RX does not work correctly: The audio stutters. The sampling rate could be affected.
#15
khut wrote: Wed Nov 04, 2020 12:59 pm Subject:
Will do. There may be something wrong...
G8ELA
#16
Unread post by G8ELA »
I upgraded from 3.0.18 to 3.0.25 today, and discovered the same issue as Chris, G4SDG. I'm using an "ordinary" Lime (non-mini).
Spent a few hours bashing my head against the problem, that'll teach me to look at the forum sooner!
Keith, G8ELA
#17
G8ELA wrote: Wed Nov 11, 2020 5:57 pm I upgraded from 3.0.18 to 3.0.25 today, and discovered the same issue as Chris, G4SDG. I'm using an "ordinary" Lime (non-mini).
Keith, G8ELA
The test team have a new kit which, I hope fixes this problem.
#18
Shout if you want to get the test kit.
DL5CV
#19
Unread post by DL5CV »
tnx for the effort on the Lime topics.
Mine is working like a charm now :) No hickups or anything else while working QO-100. Had three one hour sessions with a special callsign with lot's of rx tx switching. Also downloaded a larger winlink e-mail via qo-100 and the lime which took 30-40 Minutes.
