Page 2 of 2
Re: CloudSDR
Posted: Wed Jan 27, 2021 2:25 am
by pauldbnut
KA1GJU wrote: Tue Jan 26, 2021 6:09 pm
So you will need a bank of 4K monitors to actually see something of value with 10, 20, 30 MHz bandwidth?
For my purposes, Kriss, 32-inch 1920x1080 is great for FM BC. It's the overall band status I need first, then activity in the "holes", then any abnormalities that suggest interesting propagation.
Re: CloudSDR
Posted: Wed Jan 27, 2021 6:26 am
I would use 4k at that size. I've seen Console running on 60" 8k monitors...
Re: CloudSDR
Posted: Wed Jan 18, 2023 5:40 am
by WReeve
Is anyone running a CloudSDR with SDR Console? I cannot connect to mine and assume I have a setup problem.
Re: CloudSDR
Posted: Wed Jan 18, 2023 5:49 pm
WReeve wrote: Wed Jan 18, 2023 5:40 am
Post the logfile as an attachment.
Re: CloudSDR
Posted: Sat Jan 21, 2023 1:59 am
by WReeve
Sorry for the delay.
I've attached the logfile for a single attempt at connecting to a CloudSDR at 10.0.0.120:50112.
Re: CloudSDR
Posted: Sat Jan 21, 2023 3:08 am
by WReeve
Logfile attached for one connection attempt to a CloudSDR at 10.0.0.12:50112.
Re: CloudSDR
Posted: Sat Jan 21, 2023 6:41 am
OK, what about firewalls? I assume your local net is 10.0.0.x?
Are you sure port 50112 is correct?
Re: CloudSDR
Posted: Sun Jan 22, 2023 4:30 am
by WReeve
Yes, the application is allowed in the Windows Defender Firewall and, yes, the local net is 10.0.0.x, and, yes, the port 50112 is correct.
I use IP 10.0.0.120:50112 to connect to the radio using SpectraVue without problems.
Re: CloudSDR
Posted: Sun Jan 22, 2023 5:00 am
by WReeve
Okay, problem solved. First, my router was handing out 10.0.0.120 to a Macbook Air, so I deleted that and reserved a new address 10.0.0.112 for the CloudSDR on port 50112.
Next, I had manually added the CloudSDR in SDR Console but that didn't work. I used the SDR Console Search function for RFSpace and it found both of my CloudSDR. I saved those and now can connect okay.
Re: CloudSDR
Posted: Sun Jan 22, 2023 5:32 am
Good news
