Page 7 of 7
Re: Test Team
Posted: Sat Jan 30, 2021 8:51 am
by micked
Hi, if possible I would like to be a part of the test team, mainly use the Rx888 for 24/7 wspr and qrss grabbing, also using the rsp1a quite a bit.
73/Mikael
Re: Test Team
Posted: Mon Mar 08, 2021 10:34 pm
by chuckconner
Can you add my username (chuckconner) to the test team. I'm hoping to use 3.0.27 with the RX-888 Mk II, 3.0.26 crashes when I try to start it. Thanks!
Chuck
Re: Test Team
Posted: Wed Mar 10, 2021 2:21 am
by chuckconner
I think I'm in the test team since I can see the forum and can post in it (this is it, correct?). Why can't I find where to download the 3.0.27 kit? Are there more qualifications that must be met before access is granted? Any help appreciated!
Chuck
Re: Test Team
Posted: Wed Mar 10, 2021 7:54 am
board index
Under Test Team the title "Kits" might interest you. The hard part is finding the latest release. The board sorts by most recent entry not by creation order. The most recent is Feb 28, I think.
Re: Test Team
Posted: Wed Mar 10, 2021 4:36 pm
by chuckconner
Thanks for your reply, jdow. I look under Kits, "3.027 Kits and Release Notes" but find no download link. When I examine the "3.0.26 Kits and Release Notes" the download link is clearly available. I suspect I don't have sufficient rights yet to access 3.0.27. I've only been on the forums for a few days, been on groups.io for a long time though. Maybe someday soon! ;<)
Re: Test Team
Posted: Wed Mar 10, 2021 4:50 pm
by G0OFE
chuckconner wrote: Wed Mar 10, 2021 4:36 pm
Correct. 3.0.27 is set to be released in early April, from memory.
New Test Team members not already a current member of the io.Groups Test Team forum needs the OK from Simon.
Re: Test Team
Posted: Thu Mar 11, 2021 8:27 am
OK, I am getting cranky in my old age. But, if you can read topics and messages under *TestTeam* then for gosh sakes do it. The kits topic in *TestTeam* has many message threads. Most of them have the first message a description of what Simon changed and two links, 32-bit and 64-bit.
If you are NOT a Test Team member, faghediaboudit. 36 would be the latest you can get to.
Re: Test Team
Posted: Sun Jun 05, 2022 12:18 am
by sefirot43
Simon G4ELI wrote: Tue Aug 11, 2020 4:17 am
A set of forums are reserved for the test team, if you are in the groups.io test team or wish to join the test team set a private message via this BB to me.
Members of the test team will see the Test Team category.
Good evening,
I have been accepted to the Test Team but I cannot access the Test forum, what should I do?
Thanks.
Re: Test Team
Posted: Tue Aug 30, 2022 7:51 am
by ukdx
Can I be added to the test team please so I can share my experience of the latest beta and RX888 MK2.
