Data Analyser works perfectly on the 1st analysis of each session. But moving on to a new project results in an image which appears “noisy” and overlaid with hash. In order to get a clear image it’s necessary to close the Analyser window and re-open it from the main SDRC window.
The sequence of attached screenshots show 3 successive analyses (in order 1 to 3) without closing the window in between. I just used the tuning button to step up 9kHz from 846 and in the 3rd to step back to 846kHz. Note the difference between 1 and 3 which are both 846kHz.
No settings were changed between runs. Attachment 4 shows the settings in use.
The attachments have loaded 4 to 1 instead of the intended 1 to 4!!
Data Analyser - consecutive projects
Re: Data Analyser - consecutive projects
I hate to see these unanswered posts...
I can't solve this, but I can at least verify that I've noticed the same problem, using Data Analyser associated with Console v 3.0.27
Often the overlay of noise is so strong that it's nearly impossible to see any carrier signals through it.
best wishes,
Nick
best wishes,
Nick
Thanks Nick!
I'm sure it will be on the todo list.
Regards
Regards
