LumeSDR USB + Server not exist
Posted: Thu Apr 15, 2021 7:05 pm
Server Version V3.0.27, LimeSDR not exist in the server radio definition.
However It existed in the previous version V3.0.22
Can I fix this myself?
Or is a deeper containment required?
Updated 18.04
The console works great locally.
But in version 3.0.22, the server with Limesdr does not work.
when creating a device in version 3.0.22 and updating to 3.0.27. The radio appears in the device list. However, it does not work either.
Behavior is identical in both versions
A piece of log from a failed connection
Updated 18.04
Connecting to 192.168.178.58::50101
Connected
Sending <SVRMsg xml:lang="EN" Command="Radios" Username="admin" Password="password"></SVRMsg>
Reply
XML: <SVRMsg xml:lang="EN" Command="Radios" Defns="<SDRRadio xml:lang="EN"><RadioDefn Accounts="" Address="LimeSDR-USB, media=USB 2.0, module=FX3, serial=0009060B0049202B, index=0" Bandwidths="" DllID="limesdr.org" Enable="1" InUse="0" Model="LimeSDR-USB" Options="LimeSDR-USB, media=USB 2.0, module=FX3, serial=0009060B0049202B, index=0" Port="0" RangeHigh="3800000000" RangeLow="100000" Serial="x0049202B" Title="LimeSDR-USB" VisualGain="0.00000000000000000000"></RadioDefn></SDRRadio>
" Error="Valid"></SVRMsg>
Command: Radios
Status: Valid
Defns: <SDRRadio xml:lang="EN"><RadioDefn Accounts="" Address="LimeSDR-USB, media=USB 2.0, module=FX3, serial=0009060B0049202B, index=0" Bandwidths="" DllID="limesdr.org" Enable="1" InUse="0" Model="LimeSDR-USB" Options="LimeSDR-USB, media=USB 2.0, module=FX3, serial=0009060B0049202B, index=0" Port="0" RangeHigh="3800000000" RangeLow="100000" Serial="x0049202B" Title="LimeSDR-USB" VisualGain="0.00000000000000000000"></RadioDefn></SDRRadio>
Count: 1
Connected
Sending <SVRMsg xml:lang="EN" Command="Bandwidth" Model="LimeSDR-USB" Title="LimeSDR-USB"></SVRMsg>
Reply
XML: <SVRMsg xml:lang="EN" Command="Bandwidth" Bandwidth="" Status="✓"></SVRMsg>
Command: Bandwidth
Status: ✓
Bandwidths:
Closed
Closed
Connected
Sending <SVRMsg xml:lang="EN" Command="Soundcards"></SVRMsg>
Reply
XML: <SVRMsg xml:lang="EN" Command="Soundcards" Soundcard="Microphone (2- High Definition Audio Device)"></SVRMsg>
Command: Soundcards
Error:
Soundcards: Microphone (2- High Definition Audio Device)
Closed
Connected
Reply
Command: Bandwidth
Status: ✓
Bandwidths:
Closed
