Any way to remove the signal meter?
Posted: Fri Aug 28, 2020 7:28 am
by NO6B
I'm using 4 VRXs, so I really don't need the signal meter & it's getting in the way of the spectrum peaks. Any way to either move it to another portion of the window or just get rid of it altogether?
Bob NO6B
Re: Any way to remove the signal meter?
Posted: Fri Aug 28, 2020 9:00 am
by G0OFE
Bob,
Have you tried using the digital style meter? Takes up a lot less space vertically.
Posted: Fri Aug 28, 2020 4:46 pm
by NO6B
That's what I have it set to now, but it still hides the peaks that just so happen to be at the left end of the spectrum. I can't move the spectrum without losing one of the frequencies I need to monitor, so I'd just like to remove the signal meter completely.
Posted: Sat Aug 29, 2020 12:28 pm
by pauldbnut
NO6B wrote: Fri Aug 28, 2020 4:46 pm That's what I have it set to now, but it still hides the peaks that just so happen to be at the left end of the spectrum. I can't move the spectrum without losing one of the frequencies I need to monitor, so I'd just like to remove the signal meter completely.
Support that idea to clean up the spectrum window, with option to show in DSP panel.
Would also like to remove frequency display from spectrum, as DSP panel is almost always open here.
Would also like a toggle between full (as provided) marker display and arrowhead only.
Posted: Sun Sep 06, 2020 4:59 pm
by Antenna Maker
Try making the signal meter transparent. In ribbon bar click View. Go to Signal Meter and click the down arrow or carrot. In the drop down menu go to Analog and click the right arrow. In that drop down menu go to the bottom and click the box for Transparent. I hope this helps.
Posted: Mon Sep 07, 2020 2:46 pm
NO6B wrote: Fri Aug 28, 2020 7:28 am I'm using 4 VRXs, so I really don't need the signal meter & it's getting in the way of the spectrum peaks. Any way to either move it to another portion of the window or just get rid of it altogether?
Bob NO6B
Not at the moment.
Posted: Wed Sep 23, 2020 6:30 am
Simon G4ELI wrote: Mon Sep 07, 2020 2:46 pm
Bob NO6B
Not at the moment.
Looking at this now.
Posted: Wed Sep 23, 2020 3:34 pm
Added, will be in 3.0.25, good idea.
