Screen freezes since version 3.0.26 and 3.0.27
Posted: Sun Jun 20, 2021 7:37 am
by Dens
Since upgrading to version 3.026, I can no longer open Icon Select Radio.
When I open it, the sdr consol window freezes.
It is impossible to do anything. I can no longer select any radio station. Both locally and network... :(
Locally the sdr is RSPDUO
Only the versions under and 3.0.25 works.
Can someone help me?
Many Thank's
Merci beaucoup
Re: Screen freezes since version 3.0.26 and 3.0.27
Posted: Sun Jun 20, 2021 5:09 pm
by PD3LK
I suppose you can't send a logfile as SDRC hangs, or can you?
If you can't then i advice to go back to 3.0.25, delete all radio's in "Select Radio", re-install 3.0.26 or 3.0.27 again and add the radio again.
Pls let us know if that helped ok?
Posted: Sun Jun 20, 2021 10:42 pm
I suspect your solution will work, Leon. I think definitions changed a little about .25 to .26 transition for some types of front ends.
