ADD MINUS SIGN/BUTTON IN RECEIVER PANE
Posted: Tue Aug 03, 2021 11:01 am
Hello Simon
with the PLUS button in receiver pane you can add another receiver so far so good ... but the "X" in each of the receivers do only close and mute it but the window is still there ... either use the "x" in each receiver box to also delete it from the pane (in my view the best solution) ... and/or add a minus button (above or below the plus button) on the left side of the receiver pane (so numbers of receivers can not only be increased but you can also lower the receiver box numbers)
another possible solution would be a selection box in receiver options (see picture) that the user can select if the "x" only closes and mutes the receiver ... or if it should be also deleted from receiver pane
please find a solution that the user can decrease the number of shown receiver boxes ... the minus button added would work ... the "X" button in each receiver box also could work (not only mute and switch off but also delete it from pane)
greetz sigi dg9bfc
ps did you look for my other request?? (store ppm PER DEVICE) ?!?!?
greetz sigi dg9bfc
