Pluto SDR problem with F5OEO firmware
Posted: Sat Oct 23, 2021 8:19 pm
Odd behaviour with the OEO firmware.
Everything seems to be samplet wrong. If I set 3MHz sampling it seems close to working but is too much for my pluto on ethernet.
Using the standard 750KHz I used to is giving odd signals.
This only happens with the F5OEO firmware, with standard 0.34 it receives fine however not having PTT functionality I cannot test transmit.
Please see screenshot of behaviour.
It looks like for the first half a second (or less) is fine... see waterfall difference. Tried 3.027 and 3.1 both with same issues. Unfortunately I don't have the installer from SDR console 3.0.25 which worked fine to prove is nothing wrong on my side.
M0BOY - Las
M0BOY - Las
