What is the problem to add simultaneously decoding RDS on all frequencies from bandwidth? I guess hardware is already ready for this (in my case Elad FDM-S3 + Core i9-9900).
Thanks for the great software!
Re: Decoding RDS on all FM frequencies simultaneously
Posted: Sat Nov 27, 2021 6:24 pm
by G0OFE
The only way you can do this is open as many receivers as your machine will allow - up to 24. Each one will decode RDS.
You can set up banks of receivers in Favourites - that is what I have done. I can get away with 20, though the machine starts to creak a bit by then!
There is no current way to scan up and down the band automatically logging RDS as you go.
Posted: Sat Nov 27, 2021 6:33 pm
by Vladimir Doroshenko
Jim, thank you for the answer. I know about multi-channel monitoring since 2016 from this article.
But this method is not very comfortable. Especially, during Es.
Posted: Sun Nov 28, 2021 8:41 am
by G0OFE
Probably no ideal method.. what SDR are you using for FMDX?
It's made easier for me now I have the Elad S3 - I just record the whole band!
On playback, if RDS is logged, the log entry marks the time of the recording, rather than the current time, which is a real plus. No mental gymnastics needed.
Posted: Sun Nov 28, 2021 10:49 am
G0OFE wrote: Sun Nov 28, 2021 8:41 am
Elad FDM-S3 + 2 x AirSpy R2
I mean something like this:
Posted: Sun Nov 28, 2021 11:53 am
by G0OFE
Ah... Not seen that before.
Posted: Tue Dec 28, 2021 12:47 pm
While developers are thinking about new tools, I have to do perversions like this:
