RTL SDR & SDR Console
Posted: Sat Jan 01, 2022 6:50 pm
by kb4vwa
I'm new to the group and will read past posts to see if I can find my answer, but wanting to know if RTL-SDR V3 with SDR Console to monitor shortwave down to 75 meter 3.995 is doable? I see signal on the waterfall, but cannot decode the audio. Followed the instructions for changing to some parameter to go below 15 Mhz, and nothing.
I was hoping to save lots of time and find someone with success to send me configuration settings for my task.
Thank you
Ed - KB4VWA
Re: RTL SDR & SDR Console
Posted: Sun Jan 02, 2022 5:19 am
Pictures are called for here. Without them - we cannot help you because we cannot see your error.
That said, do not expect very much from this mode as broadcast stations are usually strong enough to make receiving other things er "challenging."
Posted: Thu Jan 06, 2022 10:34 pm
by kb4vwa
Update: As of today, I have abandoned HDSDR & HRD. Now using SDR Console 3.0.27 and all is working except I cannot get "External Radio option" under view within SDR Console to take and display within DSP window pane. I am running latest version of SDR Console 3.0.27 and Omni-rig 2.1
Any suggestions?
73's
Ed KB4VWA
Posted: Sat Jan 15, 2022 11:11 am
Does this pict provide any help?
73 Leon
Posted: Sat Jan 15, 2022 12:23 pm
by kb4vwa
Leon,
Thank you. Yes, I fixed the problem, but only after re-installing Omni-rig, the External Radio would show up in my DSP pane.
Thank you
73's
Ed
Posted: Sat Jan 15, 2022 12:24 pm
by kb4vwa
PD3LK wrote: Sat Jan 15, 2022 11:11 am
73 Leon
BTW, I am now using SDRPlay, much better receiver.
Ed
Posted: Sat Jan 15, 2022 3:13 pm
by KA1GJU
Glad you saw the 'light'!
I was going to tell you to buy a real SDR versus an $11 SDR dongle, but didn't want to come across as an arse.
I'm partial to the Airspy units due to the simplicity of operation and lack of being overwhelmed with AM BC signals on the first and second harmonic. Not to mention
I have MANY operating as SDRC Servers on my SDR server farm here in NH.
Operation is simple due to only ONE variable setting of visual gain, versus the SDRPlay's THREE variable settings. The Airspy has high and low AGC and is never touched, and the pre-amp is only used on 20M and above. I have to run the SDRPlay IF Gain in manual mode due to the AGC pumping when strong pulsed signals within the selected bandwidth, such as a strong CW station.
See the attachment for comparison between the two. The Airspy is on the left, SDR Play on the right using the same antenna via an HF multicoupler. I have four SDR's feeding from one large antenna, so it's easy to compare side by side various SDR's.
Enjoy the new SDR!
Home of the Super Station SDRC Servers in NH
