3.1 build 2470 makes me happy :-)
Posted: Fri Jan 14, 2022 6:35 pm
Hi, Simon, today I realised I was some releases behind and I noted the 3.1 build 2470 release notes showing the waterfall as playback option
Really really nice for me to play with, the possibility to choose a signal on the waterfall, for which you can set your resolution in lines per second makes it very easy to playback (unknown) satellite signals captured in a recording.
Also the progress indicator where you can see the playback is behind the signal disappearing works very convenent for me. The waterfall for a 4 hour recording with 4 MHz bandwidth (recorded on SSD) only takes seconds to generate.
The release topic itself is closed so I could not add my comments to the last topic.
Do you expect to add an option to save the generated waterfall as image ? And maybe a "minimize" icon in the right top corner, to temporarily hide the screen not having it attached to the main SDC console window ?
Thanks again !
Ben - PE2BZ
Thanks again !
Ben - PE2BZ
