Simons world map wont run
Posted: Sun Jan 30, 2022 4:31 pm
by g4eyt
Hello all
I would be grateful for any pointers please. After several downloads I cannot get Simons world map to run. I get the initial screen with no map for a few seconds then it disappears.
I have a windows 10 machine which has all the latest updates downloaded.
SDR console V3 runs well with my Hermes lite 2 (thanks Simon!)
I hope the screenshots help.
Thanks very much!
Best wishes
Colin
Re: Simons world map wont run
Posted: Sun Mar 06, 2022 4:02 pm
by James_VA3JPX
Hey Folks,
I too am having the same problem, with a slight difference in behavior.
I am running Windows10. The program installs with no problems. But when I run the program, it runs for about 2 seconds, then disappears. Task manager doesn't even show it running.
My system:
Dell Duo CPU E8400, 3Ghz
6 GB Ram
Win10 Home 21H2, OS Build: 19044.1526
Experience: Windows Features Experience Pack 120.2212.4170.0
Windows Event Viewer report for when the app crashes:
Faulting application name: SimonsWorldMap.exe, version: 1.0.0.1, time stamp: 0x61e7121c
Faulting module name: d2d1.dll, version: 10.0.19041.546, time stamp: 0xdf04746a
Exception code: 0xc0000005
Fault offset: 0x000000000002d767
Faulting process id: 0xc78
Faulting application start time: 0x01d831730941b0e4
Faulting application path: C:\Program Files\Simon's World Map\SimonsWorldMap.exe
Faulting module path: C:\WINDOWS\SYSTEM32\d2d1.dll
Report Id: f78e0386-f5d9-46cf-9478-3523f8d70fa2
Faulting package full name:
Faulting package-relative application ID:
Any advice on how I should proceed in troubleshooting the issue?
Thank you,
James
VA3JPX
Posted: Sun Mar 06, 2022 7:46 pm
From Control Panel select System and show me this.
Also I'll add BugTrap so you can forward crash dumps.
Posted: Sun Mar 06, 2022 8:41 pm
This kit
https://www.dropbox.com/s/6dhaddktjqvae ... 6.exe?dl=0 has bugtrap so should create a crash dump when it has a problem. More testing tomorrow...
Posted: Mon Mar 07, 2022 5:52 pm
by James_VA3JPX
Simon G4ELI wrote: Sun Mar 06, 2022 7:46 pm
Here you go.
Dump info sent in previous reply.
James
Posted: Mon Mar 07, 2022 6:56 pm
Thanks, I also use Core2DUO - cracking CPUs if a bit power-hungry.
Posted: Mon Mar 07, 2022 7:24 pm
Please use this kit
https://www.dropbox.com/s/3vjruh21w859o ... 7.exe?dl=0 I made an error and couldn't analyse the previous kit. With luck I'll be able to analyse this file.
