Negative value in converter offset
Posted: Sat Feb 05, 2022 9:13 am
by ik8xld
I try to make a request that was talked about some time ago, hoping to be able to describe it better and that you can have time to consider it.
Some converters have the OL frequency higher than the IF frequency and therefore it is not possible to use the current converter UP or converter DOWN configurations, because the result would be a negative value.
To be able to adapt the UP & DOWN converter definitions already existing in SDRConsole, it would be sufficient to enable the negative sign in the OFFSET field.
Thank you very much
73 Rocco IK8XLD
Re: Negative value in converter offset
Posted: Wed Feb 09, 2022 5:22 pm
by IW1DTU Fer
Hi Simon, Rocco!
Great idea Rocco, should be very useful for C-band downconverter.
Thanks and regards
Fer iw1dtu
Posted: Thu Mar 10, 2022 10:02 pm
It probably won't solve your issue but what SDRC version you are using?
I miss something in your picture....pls have a look at my attachment.
regards,
