V (overload) LED operation
wa2zkd
Unread post by wa2zkd »
My Dragonfly was working fine for a few days. Overnight, with no changes in settings or antennas the V LED came on and remains on when the radio is active regardless of whether it has any antennas. It still seems to work otherwise. Is there a way to reset that?
Re: V (overload) LED operation
Hello James
This is the support group for the SDR software, SDR Console: https://www.sdr-radio.com/
You would be better posting this question in the "Next Generation SDR" IO Group:
https://groups.io/g/NextGenSDRs
You should get a response there as the designers of your radio are also active in that group.
wa2zkd
wa2zkd
Unfortunately, there is very little traffic in the IO Group and no one has responded to me other than a suggestion to come here!
ukdx
Unread post by ukdx »
I saw your post on io but didn't respond as I coudn't offer any advice. Which model do you have, googling Dragonfly RX103 throws up a tweet from 2020 but you say it's a variant? Which model is it and this LED, is it marked as V? A photo of the SDR would help a lot.
wa2zkd
ukdx
Well I've not seen that one before! All I can suggest is if you get no luck anywhere else you tweet Justin as I think he's the source of many of these. https://twitter.com/fei666888
