usb relay not detected!
Posted: Tue Mar 08, 2022 11:53 am
by df6vw
i want to use an 5V usb relay for to control a coaxrelay and the Power amplifier.
Type:
USB 5V Relay 2 -Channel Programmable Computer Control For Smart Home.
Windows detected (sorry in german) the device as:
Der Prozess zum Hinzufügen von Dienst libusb0 für Geräteinstanz-ID USB\VID_16C0&PID_05DF\5&521A615&0&10
wurde mit folgendem Status beendet: 0.
Can i use these device to control it with SDR console?
Thanks in advance
Ralf DF6VW
Re: usb relay not detected!
Posted: Tue Mar 08, 2022 1:50 pm
Have you read
https://www.sdr-radio.com/relays? I see your relay is in the list.
Posted: Tue Mar 08, 2022 6:55 pm
by df6vw
Yes it looks the same but i can't detect nor configure in SDR console.
In your description about relay:
Select a board by serial number, then set the relay state when in receive and transmit. To test the board you can change the current relay state:
ON = Turn ON a relay channel (Activate).
OFF = Turn OFF a relay channel (Deactivate).
I am very sorry but where can i do this?
The device is detected as DigiUSG signature Digistump LLC. Maybe windows take the wrong driver.
Greetings Ralf
Posted: Tue Mar 08, 2022 7:02 pm
Here:
Posted: Thu Mar 10, 2022 4:36 pm
by df6vw
Vendor ID seems to be ok but relay wont be detected.
vy Ralf
DF6VW
Posted: Fri Mar 11, 2022 8:18 am
Sorry, I am not sure what more I can do. Please post a link to the relay board you bought.
Posted: Fri Mar 11, 2022 1:35 pm
by Barry WB2ZXJ
He seems to be using v3.0.27. Could this be a problem?
Barry
WB2ZXJ
Posted: Fri Mar 11, 2022 1:46 pm
Yes.
Posted: Sun Mar 13, 2022 5:48 pm
by df6vw
No changes with 3.1...
Posted: Mon Mar 14, 2022 7:19 pm
df6vw wrote: Sun Mar 13, 2022 5:48 pm
Try the V3.1 beta, if this doesn't help then I can only suggest the cable or the card is defective. Does the card appear in the Windows Device Manager?
