Data::Playback - Navigator Waterfall
Posted: Wed Apr 06, 2022 3:59 pm
Having finally got round to finding where it is located I have to say this is a real game changer for checking for DX in the FM band. It took just over 3 minutes to load 5 hours worth of files at 1 line/sec resolution which can then be rapidly scrolled through looking for the DX.
However I have two requests:
1. Can we have a bit more resolution time-wise, 1 line/sec is good for SpE, but one can't see shorter meteor bursts. Adding 0.2 lines/second , and 0.5 lines/second would make them visible.
2. Can it be arranged that left-clicking the mouse on the playback waterfall takes you to the time and frequency (or double-left click). Currently it just takes you to the time, and you have to go to the main window (spectrum or waterfall) to select the frequency which isn't convenient as I have the Main Window on one monitor and an expanded Playback waterfall on the other monitor.
As an suggestion - is it possible that the start and end time can be specified before the file is loaded. At present, you can only specify the start and end times, which applies just to the playback time within the full recording, after loading. So if you have a long file that you want maximum resolution for may be too large. I'm not sure what would happen as the maximum continuous run of files is 5 hours and needed 18,800 lines at 1 line/sec.
However not having the above is by no means a show-stopper and if you are into FMDX and you've not tried this - you must!
