Audio Recording using the " Wide - U " mode.
Posted: Mon Jul 25, 2022 10:46 am
by Jeremy
Many thanks for providing such an excellent and useful application.
The DSP mode "Wide-U" is of great use to me. In this mode one may set a bandwidth of up to 48kHz (F0 + - BW/2) and record the resulting signal as a file in *.wav format.
Questions :
1. What is the sample rate of the output file *.wav file ?
The sample rate may be changed as one selects different bandwidths.
2. Can one specify the sample rate ?
Or
3. Is the sample rate fixed at a maximum say 96 kilo samples per sec (ksps)?
Thanks in advance,
Jeremy.
Re: Audio Recording using the " Wide - U " mode.
Posted: Sat Jul 30, 2022 9:33 pm
For best purity of the output for future processing the data rate is not something a user can manipulate easily if at all. It is not likely a power of two multiple of 3 kHz. If it is fed through a resampler there will be a reduction in signal quality; but, programs fed the signal may work just fine. (A PSK decoder or ALE decoder would work quite well - even on the normal SSB reception.) Other decoders might find reasons to not be happy. On the whole I suspect most uses would be happy. Check the widest filter you can create and divide by about 5 or so to get the highest audio sample rate that will be meaningful. (Resampling 48 kHz to 96 kHz will still be about 20 kHz wide for the audio.)
Posted: Sun Jul 31, 2022 5:05 am
Jeremy wrote: Mon Jul 25, 2022 10:46 am
Questions :
Or
Thanks in advance,
Jeremy.
Audio is recorded at 48kHz, this is fixed.
Posted: Sun Jul 31, 2022 6:56 pm
What sample rate range might be the source rate to the resampler? If it's lower than 48 ksps then that lower rate defines the data bandwidth.
Posted: Sun Jul 31, 2022 7:11 pm
Yep,
It'll be 24kHz, same as the maximum filter width.
