Repeated Crashing when connected to local server
Posted: Mon Sep 07, 2020 10:37 pm
by M0MFX
I run a Dell latitude (i5 8gb) as a server (June 2020 build) to my i7 16gb desktop (July 2020 build) (avoids antenna feeder going across the flat). NESDR Smart and Hamitup. For months this has been fine, but in the last two weeks it crashes within minutes of connecting, then spends another five mins working on a crash report. I've made a clean install of SDR Console, as well as C++ Runtime libraries.
These problems coincided with me getting a MSI.SDR (RSP1 clone) and installing SDRUNO. The home network couldn't handle the feed from this SDR, so I've switched back to the Nooelec kit for late evening SWL and monitoring 80/40/20. SDR uno and the clone are not running / connected at the same time.
BugTrap reports "SDR Console.exe caused ACCESS_VIOLATION in module "C:\WINDOWS\SYSTEM32\MSVCR120.dll" at 0033:0000000068F0C78E, memcpy()+1118 byte(s)"
Crash report ZIP file available at
Merlin
Re: Repeated Crashing when connected to local server
Posted: Tue Sep 08, 2020 6:59 am
Quick questions:
- What bandwidth do you start the server at?
- What version of Console? If 3.0.24 I can analyse the crash dump.
Anyway, let me know the bandwidth you select and I'll see if I can reproduce this.
Posted: Tue Sep 08, 2020 10:18 am
by M0MFX
Hi Simon, yes it's 3.0.24 crashing on my desktop.
When accessing the RTLSDR (NooElec) via the server it only gives me 2.8MHz or 2.75 MHz bandwidth to choose from - it crashes with either, and I'm sure there used to be more bandwidth options.
Thank you, Merlin
Posted: Tue Sep 08, 2020 11:06 am
by M0MFX
Just an aside, but I've been running the nooelec directly in my desktop for last 40 mins and no crashes.
Posted: Tue Sep 08, 2020 11:08 am
M0MFX wrote: Tue Sep 08, 2020 10:18 am
Thank you, Merlin
Exactly which server are you using, V3 Server or RTL Dongle TCP?
Posted: Tue Sep 08, 2020 1:02 pm
by m3ghe
If he has just installed the latest SDRUno he will now be running the latest version of the SDRplay API v3.07. Before that he would've been running v3.06.
I can't say I know of the difference when running the V3 SDR-Radio server as it is one of the things I didn't test. Maybe worth considering.
Posted: Tue Sep 08, 2020 1:22 pm
by M0MFX
Hi Simon, I'm using the V3 server, have never tried connecting to a dongle over TCP
Posted: Tue Sep 08, 2020 2:17 pm
M0MFX wrote: Tue Sep 08, 2020 1:22 pm
I think I've found the bug, it's too hot & nice for coding
