Q900 SDR Radio
KD4CNO
Q900 SDR Radio
Unread post by KD4CNO »
Hi, I recently purchased a Guohedz Q900 transceiver. So far so good, but the amateur band frequencies are truncated on several bands (e.g., 40 meters is only 7000 to 7200 KHz. Is there some way to correct this to transmit on all amateur frequencies, I don't understand why, for instance, they would design the transceiver even to work on CB, but not amateur frequencies! Can you help? Thanks, and 73, KD4CNO
Re: Q900 SDR Radio
Hello Gene
Unfortunately you are in the wrong forum for your issue. This forum is specifically for support of the SDR Console SDR software written by Simon Brown G4ELI.
You might be better posting your issue in the QRZ.com forums, SDR section:
https://forums.qrz.com/index.php?forums ... o-sdr.120/
K6avp
Re: Q900 SDR Radio
Unread post by K6avp »
Basically you need to reset your ITU area setting. I believe a "how to" has been posted to the older HS2 facebook group/list and to the Radioddity QR20 fb group. It may be covered in one of the radio's Usermanuals too. There is also a Q900 fb group started by Qouhe, but it seems it is being neglected by them currently.
