Analiser, play back from cropped does not work
Posted: Thu Oct 13, 2022 6:41 pm
by pe2bz
SDRConsole 3.1 build 2575
I did run the analiser on a large recording from the 70 cm satellite band (18 hours recording) all works very nice and smooth. played back some signals from the analiser view with the "play" function and decoded some CW signals, some SSTV and so on.
Decided to give the "crop" function a go because I wanted to have a better view of a satellite around 437.140 MHz.
So, I cropped, used the Apply and waited a bit. Got a nice zoomed view including the wanted signal, however when using the play button and select one of the satellite transmissions the text in the bottom window shows the right frequency and right time but there is no signal. Tried 10 seconds backwards and 10 seconds forward, no luck.
On the attached screenshot you can see both the windows with the frequency and time. Am I doing something unexpected ?
Ben - PE2BZ
