Datafile editor problem
Posted: Fri Oct 14, 2022 9:38 am
When using the datafile editor to create a new file with differend frequency and bandwidth compared to the input recording, the resulting output file is fine until the input recording file switches to a new block.
After the switch to another block of the input recording, the center frequency of the output file changes to the original recording center frequency. The displayed frequency stays correct, but the data is not converted.
Example:
I have a recording with a center frequency of 10MHz and a bandwidth of 7MHz.
Using the datafile editor, I create a new file with a center frequency of 7MHz and a bandwidth of 1MHz.
The generated file is ok at the beginning, but jumps to 10MHz when input data originated from a new recording block. Displayed frequency stays as it shoud be.
BR,
Mike, SM0KOT
Example:
BR,
Mike, SM0KOT
