Gigabyte BLCE-4000C BRIX PC
Posted: Mon Aug 10, 2020 11:14 am
Hi All,
Received an offer this morning from https://mini-itx.com, and as a developer can never have enough computers I bought this and added 8 GB RAM. I'll put Windows 10 on and see whether there's enough grunt to run the Airspy HF+ on 144 MHz.
Gigabyte Brix GB-BLCE-4000C fully assembled PC. The Gigabyte Brix GB-BLCE-4000C features a dual core celeron cpu, ram up to 8GB Ram. It is a total fanless PC.
Base specification (this is configurable using options)
  • Intel Celeron N4000 2.6GHz
    4GB Ram DDR4
    500Gb Hard Disk
    Gigabit lan (Realtek RTL8111HS)
    Includes Wireless- Intel® Dual Band Wireless-AC 3168 & Bluetooth
    Intel UHD Graphics 600 onboard, dual display capable with HDMI and VGA outputs.
    Front 1 x Power Button, 1 x USB3.0, 1 x USB3.0 type-C
    1 x Headphone Jack, 1 x Microphoce Jack
    Rear 1 x HDMI(1.4b), 2 x USB 3.0, 1 x RJ45, 1 x VGA
    Side 1 x Kensington lock slot
    Dimension 56.22 mm x 103 mm x 116.52 mm (2.21″ x 4.06″ x 4.59″)
    Vesa mountable bracket included Supports 75 x 75 and 100 x 100 mm
    1 year parts and labour warranty
I'll report back.
Gigabyte PC Offer.jpg (216.48 KiB) Viewed 1908 times
Re: Gigabyte BLCE-4000C BRIX PC
Posted: Thu Aug 13, 2020 4:09 pm
So,
It arrived today (August 13th, 2020) and was soon up and running with Windows 10 Professional.
System:
  • Don't forget - this is a two core N4000 Celeron chip!
Verdict:
  • Hardware build quality is excellent.
  • Runs a NetSDR at 1 MHz bandwidth acceptably, also fine at 2 MHz bandwidth.
  • Graphics is usable but not fantastic.
  • Would struggle to run another resource-intensive program such as WSJT.
  • Would be fine as a server for one or two SDRs.
Future:
  • This will be used for running the g4eli.sdr-radio.com DX Cluster sometime in 2020.
Posted: Fri Oct 02, 2020 7:45 am
by pa3bwe
Tnx for the tip: I bought a similar barebone model GB-BLCE-4105C (rev. 1.0) and added 8G of ram and a 250G SSD drive.
SDRC with MSHV runs very smooth, it will be used as a remote station to get rid of the local rf-noise.
73's Antoon
