Problem with the SDR console working with the SDRplay RSPDuo
Posted: Fri Dec 30, 2022 11:14 am
by peterh
My name is Peter and I have been a radio amateur with the call sign DO1PH for 2 months.
I have a problem with the SDR console working with the SDRplay RSPDuo.
I monitor with the RSPDuo 2 pan adapter (1st IF 38.85MHz for 2m, 2nd IF 46.35MHz for 70cm).
I can select tuner A or B to watch the respective IF.
But in order to display the real frequencies, I have to enter different offset frequencies for 2m and 70cm under "Converter Definition".
I also have to select "Invert Spectrum" in the 2m band.
But since I can only select the RSPDuo once under "Select Radio", I always have to "Stop" -> "Select Radio" -> Select Converter -> select "Invert Spectrum" (at 2m)
when changing bands (2m or 70cm) - > Press "Start".
A new instance cannot be used either, because the RSPDuo cannot be selected a second time in the "Radio Definitions".
Is there a way for tuner A and B to define the offset frequency and "invert spectrum"?
greeting
Peter
Re: Problem with the SDR console working with the SDRplay RSPDuo
Posted: Sat Dec 31, 2022 11:42 pm
peterh wrote: Fri Dec 30, 2022 11:14 am
greeting
Peter
Hello Peter
I don't have SDR Duo but from everything I've read on here, I don't think this can be done. Also seems confirmed by Simon's own notes on this receiver:
https://www.sdr-radio.com/sdrplay#RSPduo
"RSPduo. Currently this software only supports one receiver at a time."
You would need two physically separate receivers and two instances of SDRC, one for each receiver. SDRC can only be connected to one piece of hardware per instance.
Posted: Sun Jan 01, 2023 9:45 am
by peterh
Hi Max,
thanks for the information.
But unfortunately I don't know any other SDR software that can do that.
I had bought the RSPDuo especially, in the hope that I could monitor 2 frequency bands with different offset frequencies with both receivers.
That's really too bad.
greeting
Peter
Happy New Year 2023!
Posted: Tue Jan 03, 2023 12:22 pm
by peterh
Thanks for the information!
Peter
Posted: Thu Jan 05, 2023 10:32 pm
peterh wrote: Sun Jan 01, 2023 9:45 am unfortunately I don't know any other SDR software that can do that.
I thought that was possible in SDR Uno? I don't use it because I loath the GUI. I think it's an ergonomic mess, but to be fair that's only my opinion and some people seem to get along OK with it.
When you say "different offset frequencies" then I assume you are perhaps talking about converter offsets? If that's the case then I think you would be back to my suggestion, i.e. something like two RSPdx receivers (or any two different hardware receivers), each one running in a separate instance of SDR Console. I think maybe the original idea of the RSPDuo was more to enable experimentation with dual-diversity reception?
Happy New Year to you also.
