Skipping Waterfall-Spectra with other USB Program
Posted: Fri Jan 27, 2023 3:22 am
Thanks for accepting me as a member.
I am having an issue with SDR Console 3.2 with the Waterfall and Spectrum "skipping".
This only happens with one specific program called Wavenode which is a Wattmeter USB Device.
None of my other USB Devices or Programs on the computer cause this, Wavenode is the only one.
Note - this anomaly happens even when there is nothing being transmitted i.e. No RF being generated for the wattmeter.
I am running SDR Console Ver 3.2 from September 18th, 2022
API Ver 3.09
My SDR Unit is an SDRPlay RSP2.
The Waveode Wattmeter Unit is called a WN-2.
Here is a link to their website:
https://wavenodedevelop.com/controllers/wavenode-wn-2/
This does not happen with SDRuno Ver 1.42 1014 (API Ver 3.09) at any of its Bandwidth settings from 2Mhz to 10Mz.
SDRuno works fine with the Wavenode program with no skipping.
Here is a link to my server that shows a video of SDR Console skipping when I start the Wavenode Program.
As you can see in the video, it stops skipping and acts normal when the Wavenode program is closed.
Note - This is a 30mB file:
http://www.wz5q.net/images/sdr_console_ ... 6-2023.mp4
My computer is:
Motherboard - ASUS Z77-A
CPU - Intel I7-3770 3.4Ghz, 4 Core, 8 Thread
Memory - 8MB of DDR3 GSkill
Video Card - AMD Radeon HD 6670
Disks - Solid State Samsung
Operating System - Windows 10 64bit with latest updates
I have tried changing all different settings in SDR Console with no effect.
This includes the Bandwidth settings, there is no difference in the skipping between 500Khz and 10Mhz.
No difference in the skipping with changes in Resolution either.
My Video card does not support CUDA, but it is working in OpenCL.
I have reverted it to IPP and the skipping is still there with Wavenode running.
It seems to be an issue with the USB when both programs are running.
It's not a matter of CPU load or other resources as the load on SDR Console never goes over 15% and Wavenode not over 5%.
I have run Prime95 to load all the Cores to 100% and SDR Console is still smooth, until Wavenode is started.
I have read and applied all the info on the USB Page of this website with No change in the skipping.
I have both of these USB Devices on the same USB 3.0 Hub, with nothing else connected.
Power draw and Bandwidth Consumed is not in excess with either USB Device:
SDRplay RSP2 - Power = 100mA -- Bandwidth Consumed = 3%
Wavenode - Power = 98mA -- Bandwidth Consumed = 2%
Please review the information I provided and if anything else is needed let me know and I will provide it.
I like SDR Console and would prefer to use it rather then SDRuno.
Thank You in advance.
API Ver 3.09
My computer is:
