IQ recording of entire MW band
Posted: Thu Mar 23, 2023 2:52 am
by Lyn
I am using the latest version of Console with an Airspy HF Discovery, bandwidth set at 912kHz. I would like to make IQ recordings of the entire MW band from 530kHz to 1710kHz. I tried using the MW settings in Favourites but the resulting recordings only covers 670 to 1560kHz. is there a way to set the IQ recording up so the entire MW band is recorded? I have been able to do that with a RSPDx and SDRUno so I assume I should be able to do the same with Console and the Airspy.
Lin
Re: IQ recording of entire MW band
Posted: Thu Mar 23, 2023 7:32 am
by G4ZFQ
Lin,
"Airspy HF Discovery, bandwidth set at 912kHz." says it all.
The Discovery is a low cost high performance SDR - the trade-off is bandwidth.
It is impossible to record more than the sample rate, in fact it is best to use somewhat less than the maximum.
Alan
Posted: Thu Mar 23, 2023 3:57 pm
by Lyn
Alan,
That is really too bad. The Airspy/YouLoop combination is ideal for travel. Guess it's back to the RSPDx when I'm home. Though that receiver is portable too, I find it needs a better antenna than the YouLoop, probably because it doesn't have the internal pre-amp the Airspy has. Maybe one of the companies will come up with a receiver than combines the best features of both someday.
Linda
