HF Noise Jump - Wellgood Loop / RX-888 MKII
Posted: Tue May 09, 2023 5:54 pm
by skyking_comms
I have been testing a Wellgood Loop Antenna with an RX-888 MKII. I've been getting impressive results, especially around 5 MHz for the UK Aero Volmets where there is a low noise floor.
But I have a huge noise jump from around 8.5 MHz to 12 MHz which is active 24/7. I've turned off all electricals in the house, used a linear PSU, moved the loop to different locations in the garden and replaced my cable connectors - but the noise jump is still there. It's annoying at it's in the aero band I'm most interested in.
Wondering if anyone has any ideas on what it could be based on the shape of the noise jump?
For anyone interested in more information on the Wellgood there is a good write up here - http://www.merseyradar.co.uk/m1geo-well ... op-antenna
Re: HF Noise Jump - Wellgood Loop / RX-888 MKII
Posted: Wed May 10, 2023 1:55 am
by KA1GJU
I have an active loop that I use for DF'ing noises (RFI). I plot the nulls on a paper map (google map in satellite map mode zoomed in to the neighborhood) or use APRS.fi and use the plotter tool zoomed in on a satellite map thats zoomed in. Neighbors treadmill and leaky powerlines were found using mine, as well as getting bearings on QRM on lower ham bands.
Use the tools you have to zero in on the noise, the loop antenna!
The second image you posted is of +2MHz of bandscope, if you zoom in you may find that they may be HF BC stations, see my humble 912kHz wide images attached. There are lots of them in that 31m band and 25m band! One really needs to zoom in and look for repeating QRM signals, such as every xx kHz along the spectrum. When looking at 1MHz or more of bandwidth at one time, you miss out on all the nuances hidden inbetween the -30dBm BC stations!
The activity I see in your 2nd screen shot, happens to fall right in those two bands (31 and 25m). If I were a gambling man, I would say you are hearing the HF BC stations!
EDIT!
I just realized you were speaking of the noise floor! Not the strong signals. My bad!
Could it be the result of the band pass filters kicking in or out? I can't seem to locate what the RX-888 has for filters or when they become active or inactive. My SDR-iq has mechanical
filters, while a user is using it on my server, I know when they are making large frequency changes. Ka-chunk... ka-chunk...
Posted: Tue Feb 11, 2025 1:19 pm
by HB9VQQ
It's a known issue with the Wellgood Amp both with V3 and V4
Posted: Tue Feb 11, 2025 5:23 pm
HB9VQQ wrote: Tue Feb 11, 2025 1:19 pm It's a known issue with the Wellgood Amp both with V3 and V4
Never heard that one before. Any links to further information? I've Googled but cannot find any reference to it? Or any ideas what is the suggested source of the noise? Sounds odd to have such a clearly defined boundary in wideband amplifier.
Posted: Wed Feb 12, 2025 11:28 am
by skyking_comms
This is an old post - I've since updated my findings here https://www.airband-radio.co.uk/rfi/
Posted: Thu Feb 13, 2025 9:53 am
skyking_comms wrote: Wed Feb 12, 2025 11:28 am This is an old post - I've since updated my findings here https://www.airband-radio.co.uk/rfi/
Interesting detective work. Thanks.
Posted: Mon Feb 24, 2025 7:22 am
by HB9VQQ
