Missing 'Dither' setting
Posted: Wed May 17, 2023 9:53 am
Hi
I am using the HL2 with the band-volt modification to automatically change the band on my linear amplifier (it sends a specific voltage per-band to the amp).
It's explained here: https://github-wiki-see.page/m/softerha ... Band-Volts
This mod implements the PWM required with a code element in the later versions of gateware on the HL2. To enable the PWM signal. the software uses the 'Dither' setting of the Hermes protocol since this is not otherwise used on the HL2
I'm keen to switch from Thetis to SDR console, but I can't seem to find the checkbox to enable 'Dither'. for example on Thetis, it's in the Hermes settings area under U/W Select.
Can anyone tell me that I'm being dumb and it can be set in the SDR Console, or if not, is there a way this setting could be added to the GUI?
Many thanks
Mark
Many thanks
Mark
