RX888MKII - Server Definition
Posted: Fri Aug 11, 2023 11:59 pm
by Vincent
Greetings,
Does the SDRC server definition work for the RX888 MKII? When I try to start the RX888MKII nothing happens. Please help.
Vincent
Re: RX888MKII - Server Definition
Posted: Sun Aug 13, 2023 3:29 pm
Vincent wrote: Fri Aug 11, 2023 11:59 pm
Greetings,
Vincent
Can I suggest that you read the following links. RX888 seems sometimes to be very straightforward to install, sometimes a bit tricky, and nearly always related to the way the driver is set up. The two IO Group posts may not directly relate to your exact issue but there is a good discussion on there related to installing the drivers which may prove useful to read through:
https://www.sdr-radio.com/rx-666
https://sdr-radio.groups.io/g/main/topi ... /100636949
https://sdr-radio.groups.io/g/main/topi ... /100714499
