Mis identified FMduo
Posted: Wed Sep 27, 2023 3:23 pm
by VK7JEM
Small issue I have with my fmduo tx/rx is that sdr console identifies it as rx only model
As such I have no way to switch antennas.
Also I cant see a way to disable LPF and thus go past 54 MHz
Any ideas team?
Re: Mis identified FMduo
Posted: Wed Sep 27, 2023 9:17 pm
I believe that the answer to both of these issues is in this information page?
https://www.sdr-radio.com/elad-transceiver
See in the section headed "Duo". Namely "TX Output" setting and also "Filter" setting.
Also that Elad Menu Item 30 is set "TX Enable" to On.
Posted: Thu Sep 28, 2023 6:34 am
VK7JEM wrote: Wed Sep 27, 2023 3:23 pm Small issue I have with my fmduo tx/rx is that sdr console identifies it as rx only model
Any ideas team?
You've probably searched for the wrong ELAD radio.
Posted: Fri Sep 29, 2023 5:27 am
by VK7JEM
HI
Further on this
When I search for fmduo tx rx it says none found, but when i search for rx it reports it.
Nor do I have the "radio" panel that the web page shows
However I have had one thought. Because I am only using it as an RX and I have amplified active antennas on both ant ports, I have turned 30 off so I dont zap the antennas by accident.... Might play with that...
Posted: Sat Sep 30, 2023 1:41 am
by VK7JEM
Still learning
yes if i enable option 30 then console registers it as txrx - so thats the answer to that!
also i found the LPF toggle. but it only is present on the pc the elad is connected to.
I use server to myother pcs in different rooms. they dont get that feature. I can live with that
Still cant see that radio panel or antenna switch tho
Posted: Sun Oct 01, 2023 2:59 pm
VK7JEM wrote: Sat Sep 30, 2023 1:41 am Still cant see that radio panel or antenna switch tho
Have you got the RX DSP enabled? The Radio panel lives in there!
