Low audio from SDR Console
Posted: Wed Feb 21, 2024 3:31 am
A continuing problem, I am having with the SW is that my audio levels are very low. I am listening to WWV right now as selected from the favorites menu. My volume level is set to 50% and i have head phones on the signal is above S9+20 and yet I can hardly hear the audio. All other computer sounds are blasting. Computer volume is set at 50%. I should not be able to have my head phones at this level. Why is the audio so low? again all other computer sounds are at the level you would expect. Hope the screen shot helps.
Radio is RSPDX, all other console options are off. AGC is set to slow. Off results in high sound level if slider is moved to the right but also creates distortion.
