Alternate?
Posted: Wed May 08, 2024 8:32 pm
by Homer1952
Suddenly, I am have trouble connecting either radio (HF+ and RSP2) to Console. Console launches fine & finds the radios but then Console fails to respond when I try to mate it with a radio. This happened on 3.2 & 3.3.
After connecting with Simon a bit, I uninstalled 3.3 again & tried searching for any remains of Console & was successful at deleting some or all.
I reinstalled 3.3, pinned it to the toolbar & was able to connect with the Airspy HF+ discovery. But when I tried to connect later I got the "please wait" & ultimately fail of Console once again. ???
After I shut down Console, for whatever reason, I right clicked on the Console icon in the toolbar & found multiple options: Alternate, reset & others.
So I tried Alternate & that version will load & run the HF+.
I am OK running Console that way, but still wonder why I have to select Alternate instead of the "main stream" (my term) Console.
Thanx - Bob
Re: Alternate?
Posted: Thu May 09, 2024 8:54 am
Those sound like alternative identities you created. It appears one of them has gone fubar. The ones that do not work should be removed. I am not sure if Simon has a good way to do that or not. (I tend to brute force it.) Note that "reset" will allow you to start over. It nukes all identities.
