SDR Console does not want to start …
Posted: Thu Jun 20, 2024 2:36 pm
by Libauswl
Hello!
I am looking for help, explanation, ideas for my situation..
I'm a SDR Console user from ver 3.0.26 (2020-12-14) and now I'm @ ver 3.3 build 3236 from (2024-02-05)
Strange things started a month ago - the program did not start (the frequency can be changed, the clock works, IQ recording can be played without problems ) and any changes in the interface ( program appearance ) can also be made without problems.
The program can only be run by completely uninstalling and reinstalling it. You can let her go again 2-3 times, but then she hangs up. I have tried to create a second identity, run the program in safe mode - the result does not change.
I prepared a dump file, but I don't know whether to send it to the address ....simon@sdr-radio.com (link to file )
In short, I will be waiting for any explanation / suggestions about my situation
Sorry for my English.
73! de YL3GIE
libauswl@lrg.lv ( veto@lrg.lv )
Re: SDR Console does not want to start …
Posted: Fri Jun 21, 2024 2:50 am
Check the radio's definition entry. Driver updates or other updates may render old definitions unusable. So creating a new one may allow it to work again.
{^_ ^}
Posted: Thu Aug 15, 2024 12:40 pm
by K1FSY
If you are using cuda support try turning it off before pressing play and see if it works with CPU. I started having GPU issues with later releases but switched to cpu without issue. It would lock up though and have to be killed.
