Select Satellite (, 0 available)
Posted: Fri Jul 19, 2024 6:28 pm
Hoping someone can help. I've been using Simon's World Map for a while and never had an issue setting up satellites. Earlier in the week I noticed that the ISS tracking had fallen behind and refreshed the GPData. From that point on, I have no satellite tracking, my main and other satellite lists are gone, and I cannot reselect them because I do not have a list of satellites ( Select Satellite (, 0 available) ).
I have tried all three options under Select the data set. I did initially get 'timed out' on the Celestrak servers, so I am waiting several hours between attempts now. I uninstalled the software and reinstalled from a fresh download of v1.4 (although I suspect something was left behind because my map preferences carried over).
Log file is below after an attempt to refresh the 'Active' data set. Afterwards I still show Select Satellite (, 0 available)
Any thoughts on how I can fix this?
WorldMap, 14:25:25.348: SatDataLoad
WorldMap, 14:25:25.348: File ..: Active
WorldMap, 14:25:25.348: Flag ..: Reload
WorldMap, 14:25:25.348: -
WorldMap, 14:25:25.348: Downloading: https://celestrak.org/NORAD/elements/gp ... FORMAT=xml
WorldMap, 14:25:25.348: Opening: https://celestrak.org/NORAD/elements/gp ... FORMAT=xml
WorldMap, 14:25:25.356: Background> LoadSatellites
WorldMap, 14:25:25.356: Background> URL .....: https://celestrak.org/NORAD/elements/gp ... FORMAT=xml
WorldMap, 14:25:25.356: Background> Group ...: Active
WorldMap, 14:25:25.356: Background> Flag ....: Reload
WorldMap, 14:25:25.356: Background> -
WorldMap, 14:25:25.356: Background> Prev ....: 19-07-2024
WorldMap, 14:25:25.356: Background> Today ...: 19-07-2024
WorldMap, 14:25:25.356: Background> Loading .: https://celestrak.org/NORAD/elements/gp ... FORMAT=xml
WorldMap, 14:25:25.706: URL opened, handle x00CC000C, The operation completed successfully.
WorldMap, 14:25:25.706: https://celestrak.org/NORAD/elements/gp ... FORMAT=xml Read finished, 1829 bytes read
WorldMap, 14:25:25.706: Closed
WorldMap, 14:25:25.706: -
WorldMap, 14:25:25.707: Background> Status ..: 1
WorldMap, 14:25:25.707: Background> Loaded ..: 38
WorldMap, 14:25:25.707: Background> -
WorldMap, 14:25:25.710: Background> XML .....: <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-str...
WorldMap, 14:25:25.710: Background> XML .....: ...rg">ts.kelso@celestrak.org</a> if you have questions.</h3>
</fieldset></div>
</div>
</body>
</html>
WorldMap, 14:25:25.710: Background> -
</fieldset></div>
</div>
</body>
</html>
