Not getting full bandwidth on RSPDUO
Posted: Wed Aug 28, 2024 1:43 am
by KO4PRE
I am using and RSPDUO with the bandwidth set to 10MHZ. I have 3 receivers at the FT8 frequencies for 10M, 12M, and 15M. When I select the 15M receiver, the audio on the 10M receiver goes away. The greatest spread between the receivers with audio on all 3 is about 5 MHz.
How can I get receiver audio across the full 10MHz bandwidth of the RSPDUO?
Bruce Schober
KO4PRE
Re: Not getting full bandwidth on RSPDUO
Posted: Wed Aug 28, 2024 11:14 pm
KO4PRE wrote: Wed Aug 28, 2024 1:43 am
Bruce Schober
KO4PRE
Select the middle frequency radio (24MHz) then on the Home tab, in the "Radio" section, press "Lock". See picture:
https://drive.google.com/file/d/14evw-t ... sp=sharing
This locks the radio local oscillator and you can then select any of the three radios without losing top or bottom one. With bandwidth of 10MHz this gives you virtual receiver coverage coverage 24MHz plus or minus 5MHz.
To verify I tried it on my RSP2 and it works fine.
Hope it helps.
Posted: Thu Aug 29, 2024 1:55 am
by KO4PRE
Thanks Max.
