I can run the SDRConsole
Posted: Sat Oct 19, 2024 1:42 pm
by BG5CVT
When I double click the program,the program will appear on taskmanager for 1 sec and then disappear.It means it only run for 1 sec and crush.It crush too fast to create the dump file.So I can't collect any dump files from taskmanager.
I used a software called DebugView to try getting some error log.Luckily,I got it.
When I run the SDRConsole,I get a error log on DebugView:
"[23980] FTH: (23980): *** Fault tolerant heap shim applied to current process. This is usually due to previous crashes. ***"
That's all I can get from the DebugView.
Then is my computer information.
CPU:Intel E5-2697V3
System:Windows 11 WorkStation 64 bits(10.0,version 22635)
RAM:16GB DDR4
DirectX Version:12
Re: I can run the SDRConsole
Posted: Sat Oct 19, 2024 9:31 pm
BG5CVT wrote: Sat Oct 19, 2024 1:42 pm
CPU:Intel E5-2697V3
RAM:16GB DDR4
DirectX Version:12
Xeon E5-2697V3 dates from 2014. One point is it's not listed as compatible with Windows 11 (of course, because Win 11 only came in 2021). So that's one issue.
Which version of SDR Console are you using? You need latest version here, and only here..... no third party downloads:
https://www.sdr-radio.com/download#Release
You do not mention any GPU. SDRC ideally needs a reasonable quality GPU. Which GPU are you running?
Posted: Sat Nov 09, 2024 2:46 am
by BG5CVT
I used SDR Console V3,the latest version.My GPU is Nvidia GTX 760.And I used a new program to get the actions before it crashed:
1-22:04:52.5894981 SDR Console.exe 18736 EXEC_create D:\SDR-Radio.com (V3)\SDR Console.exe parent_pid:12104 image_base:0x00007FF6002E0000 image_size:0x01AA5000 cmdline:"D:\SDR-Radio.com (V3)\SDR Console.exe" 0x00000000 [操作成功完成。 ]
2-22:04:52.5950821 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\ntdll.dll base:0x00007FFBCD970000 size:0x00217000 0x00000000 [操作成功完成。 ]
3-22:04:52.5960701 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\CodePage access:0x00020019 0x00000000 [操作成功完成。 ]
4-22:04:52.5960701 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\CodePage\ACP type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
5-22:04:52.5960701 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\CodePage\OEMCP type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
6-22:04:52.5960701 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager access:0x00000001 0x00000000 [操作成功完成。 ]
7-22:04:52.5960701 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager access:0x00000009 0x00000000 [操作成功完成。 ]
8-22:04:52.5960701 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager access:0x00000009 0x00000000 [操作成功完成。 ]
9-22:04:52.5970595 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\kernel32.dll base:0x00007FFBCC2D0000 size:0x000C4000 0x00000000 [操作成功完成。 ]
10-22:04:52.5970595 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\KernelBase.dll base:0x00007FFBCAEF0000 size:0x003BA000 0x00000000 [操作成功完成。 ]
11-22:04:52.5980904 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\DLL access:0x00020019 0x00000000 [操作成功完成。 ]
12-22:04:52.5980904 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\safer\codeidentifiers access:0x00000001 0x00000000 [操作成功完成。 ]
13-22:04:52.5991313 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\FileSystem access:0x00020019 0x00000000 [操作成功完成。 ]
14-22:04:52.5991313 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\FileSystem\LongPathsEnabled type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
15-22:04:52.5991313 SDR Console.exe 18736 FILE_open C:\Windows\System32\apphelp.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
16-22:04:52.5991313 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
17-22:04:52.5991313 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
18-22:04:52.5991313 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\apphelp.dll base:0x00007FFBC58B0000 size:0x00097000 0x00000000 [操作成功完成。 ]
19-22:04:52.5991313 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags access:0x00000001 0x00000000 [操作成功完成。 ]
20-22:04:52.6000910 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags access:0x00000001 0x00000000 [操作成功完成。 ]
21-22:04:52.6000910 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\SdbUpdates access:0x00020019 0x00000000 [操作成功完成。 ]
22-22:04:52.6000910 SDR Console.exe 18736 FILE_open C:\Windows\apppatch\sysmain.sdb access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
23-22:04:52.6000910 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\SdbUpdates access:0x00020019 0x00000000 [操作成功完成。 ]
24-22:04:52.6000910 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\SdbUpdates\ManifestedMergeStubSdbs access:0x00020019 0x00000000 [操作成功完成。 ]
25-22:04:52.6010844 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\SdbUpdates\ManifestedMergeStubSdbs\C:\Windows\apppatch\MergeSdbFilesSource\sysMerge.sdb type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
26-22:04:52.6010844 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\SdbUpdates access:0x00020019 0x00000000 [操作成功完成。 ]
27-22:04:52.6010844 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\SdbUpdates access:0x00020019 0x00000000 [操作成功完成。 ]
28-22:04:52.6010844 SDR Console.exe 18736 FILE_open C:\Windows\apppatch\MergeSdbFilesSource\sysMerge.sdb access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
29-22:04:52.6010844 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders access:0x00000001 0x00000000 [操作成功完成。 ]
30-22:04:52.6010844 SDR Console.exe 18736 REG_getval HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\Cache type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
31-22:04:52.6010844 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers access:0x00020019 0x00000000 [操作成功完成。 ]
32-22:04:52.6010844 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers access:0x00020019 0x00000000 [操作成功完成。 ]
33-22:04:52.6010844 SDR Console.exe 18736 REG_getval HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers\D:\SDR-Radio.com (V3)\SDR Console.exe type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
34-22:04:52.6010844 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\SDR Console.exe access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000001 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
35-22:04:52.6010844 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders access:0x00000001 0x00000000 [操作成功完成。 ]
36-22:04:52.6010844 SDR Console.exe 18736 REG_getval HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\Cache type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
37-22:04:52.6010844 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\SdbUpdates access:0x00020019 0x00000000 [操作成功完成。 ]
38-22:04:52.6010844 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\SdbUpdates\ManifestedMergeStubSdbs access:0x00020019 0x00000000 [操作成功完成。 ]
39-22:04:52.6010844 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\SdbUpdates\ManifestedMergeStubSdbs\C:\Windows\apppatch\MergeSdbFilesSource\sysMerge.sdb type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
40-22:04:52.6010844 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\SdbUpdates access:0x00020019 0x00000000 [操作成功完成。 ]
41-22:04:52.6010844 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\SdbUpdates access:0x00020019 0x00000000 [操作成功完成。 ]
42-22:04:52.6010844 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\SDR Console.exe access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000001 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
43-22:04:52.6010844 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders access:0x00000001 0x00000000 [操作成功完成。 ]
44-22:04:52.6010844 SDR Console.exe 18736 REG_getval HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\Cache type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
45-22:04:52.6026254 SDR Console.exe 18736 FILE_open C:\Windows\System32\AcLayers.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
46-22:04:52.6026254 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
47-22:04:52.6026254 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
48-22:04:52.6036571 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\AcLayers.dll base:0x00007FFBB2E90000 size:0x004AA000 0x00000000 [操作成功完成。 ]
49-22:04:52.6036571 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\msvcrt.dll base:0x00007FFBCB7D0000 size:0x000A7000 0x00000000 [操作成功完成。 ]
50-22:04:52.6036571 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\shlwapi.dll base:0x00007FFBCC270000 size:0x0005E000 0x00000000 [操作成功完成。 ]
51-22:04:52.6036571 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags access:0x00000001 0x00000000 [操作成功完成。 ]
52-22:04:52.6046753 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001 access:0x02000000 0x00000000 [操作成功完成。 ]
53-22:04:52.6046753 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001 access:0x02000000 0x00000000 [操作成功完成。 ]
54-22:04:52.6046753 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001 access:0x02000000 0x00000000 [操作成功完成。 ]
55-22:04:52.6046753 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Control Panel\Desktop access:0x00020019 0x00000000 [操作成功完成。 ]
56-22:04:52.6046753 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001 access:0x02000000 0x00000000 [操作成功完成。 ]
57-22:04:52.6046753 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Control Panel\Desktop\MuiCached access:0x00020019 0x00000000 [操作成功完成。 ]
58-22:04:52.6046753 SDR Console.exe 18736 REG_getval HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Control Panel\Desktop\MuiCached\MachinePreferredUILanguages type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
59-22:04:52.6056684 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager access:0x00000009 0x00000000 [操作成功完成。 ]
60-22:04:52.6056684 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\CustomLocale access:0x00020019 0x00000000 [操作成功完成。 ]
61-22:04:52.6066688 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\ExtendedLocale access:0x00020019 0x00000000 [操作成功完成。 ]
62-22:04:52.6066688 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\Sorting\Versions access:0x00020019 0x00000000 [操作成功完成。 ]
63-22:04:52.6066688 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\Sorting\Versions\ type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
64-22:04:52.6066688 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\Sorting\Versions\000604xx type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
65-22:04:52.6066688 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\Sorting\Versions\FF0406xx type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
66-22:04:52.6066688 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager access:0x00000001 0x00000000 [操作成功完成。 ]
67-22:04:52.6066688 SDR Console.exe 18736 FILE_open C:\Windows\System32\SortWindows6Compat.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
68-22:04:52.6066688 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
69-22:04:52.6066688 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
70-22:04:52.6066688 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\SortWindows6Compat.dll base:0x00007FFBC65A0000 size:0x00015000 0x00000000 [操作成功完成。 ]
71-22:04:52.6076671 SDR Console.exe 18736 FILE_open C:\Windows\Globalization\Sorting\SortVistaCompat.nls access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000001 disposition:0x00000001 options:0x00020060 0x00000000 [操作成功完成。 ]
72-22:04:52.6076671 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\user32.dll base:0x00007FFBCC540000 size:0x001AF000 0x00000000 [操作成功完成。 ]
73-22:04:52.6086690 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\win32u.dll base:0x00007FFBCAC60000 size:0x00026000 0x00000000 [操作成功完成。 ]
74-22:04:52.6086690 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\gdi32.dll base:0x00007FFBCC240000 size:0x00029000 0x00000000 [操作成功完成。 ]
75-22:04:52.6086690 SDR Console.exe 18736 FILE_open C:\Windows\System32\mfc140u.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
76-22:04:52.6086690 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\gdi32full.dll base:0x00007FFBCAC90000 size:0x0011B000 0x00000000 [操作成功完成。 ]
77-22:04:52.6086690 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\msvcp_win.dll base:0x00007FFBCAE20000 size:0x0009A000 0x00000000 [操作成功完成。 ]
78-22:04:52.6086690 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\ucrtbase.dll base:0x00007FFBCB330000 size:0x00111000 0x00000000 [操作成功完成。 ]
79-22:04:52.6096420 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\advapi32.dll base:0x00007FFBCC6F0000 size:0x000B2000 0x00000000 [操作成功完成。 ]
80-22:04:52.6096420 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\sechost.dll base:0x00007FFBCBFE0000 size:0x000A8000 0x00000000 [操作成功完成。 ]
81-22:04:52.6096420 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\bcrypt.dll base:0x00007FFBCAEC0000 size:0x00028000 0x00000000 [操作成功完成。 ]
82-22:04:52.6096420 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\rpcrt4.dll base:0x00007FFBCB680000 size:0x00114000 0x00000000 [操作成功完成。 ]
83-22:04:52.6096420 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\shell32.dll base:0x00007FFBCD0B0000 size:0x0087B000 0x00000000 [操作成功完成。 ]
84-22:04:52.6106667 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\ole32.dll base:0x00007FFBCBCC0000 size:0x001A5000 0x00000000 [操作成功完成。 ]
85-22:04:52.6106667 SDR Console.exe 18736 FILE_open C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.22621.4291_none_2715d3a373803e45\comctl32.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
86-22:04:52.6106667 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\combase.dll base:0x00007FFBCB880000 size:0x0038F000 0x00000000 [操作成功完成。 ]
87-22:04:52.6106667 SDR Console.exe 18736 FILE_open C:\Windows\System32\uxtheme.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
88-22:04:52.6106667 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
89-22:04:52.6106667 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
90-22:04:52.6106667 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
91-22:04:52.6106667 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\oleaut32.dll base:0x00007FFBCCA50000 size:0x000D7000 0x00000000 [操作成功完成。 ]
92-22:04:52.6116660 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\mfc140u.dll base:0x00007FFB52F40000 size:0x0056B000 0x00000000 [操作成功完成。 ]
93-22:04:52.6116660 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\ws2_32.dll base:0x00007FFBCC3A0000 size:0x00071000 0x00000000 [操作成功完成。 ]
94-22:04:52.6106667 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
95-22:04:52.6116660 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\uxtheme.dll base:0x00007FFBC6E10000 size:0x000B1000 0x00000000 [操作成功完成。 ]
96-22:04:52.6106667 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
97-22:04:52.6116660 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\imm32.dll base:0x00007FFBCC160000 size:0x00031000 0x00000000 [操作成功完成。 ]
98-22:04:52.6116660 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
99-22:04:52.6116660 SDR Console.exe 18736 FILE_open C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.22621.4291_none_5800c688ce12b813\GdiPlus.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
100-22:04:52.6116660 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
101-22:04:52.6126648 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
102-22:04:52.6126648 SDR Console.exe 18736 FILE_open C:\Windows\System32\msvcp140.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
103-22:04:52.6126648 SDR Console.exe 18736 EXEC_module_load C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.22621.4291_none_5800c688ce12b813\GdiPlus.dll base:0x00007FFBB8560000 size:0x001BA000 0x00000000 [操作成功完成。 ]
104-22:04:52.6126648 SDR Console.exe 18736 EXEC_module_load C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.22621.4291_none_2715d3a373803e45\comctl32.dll base:0x00007FFBAC730000 size:0x00292000 0x00000000 [操作成功完成。 ]
105-22:04:52.6126648 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
106-22:04:52.6126648 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
107-22:04:52.6126648 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\msvcp140.dll base:0x00007FFBABFE0000 size:0x0008D000 0x00000000 [操作成功完成。 ]
108-22:04:52.6126648 SDR Console.exe 18736 FILE_open C:\Windows\System32\version.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
109-22:04:52.6126648 SDR Console.exe 18736 FILE_open C:\Windows\System32\winmm.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
110-22:04:52.6132108 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
111-22:04:52.6132108 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
112-22:04:52.6132108 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
113-22:04:52.6132108 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\version.dll base:0x00007FFBC4E60000 size:0x0000A000 0x00000000 [操作成功完成。 ]
114-22:04:52.6132108 SDR Console.exe 18736 FILE_open C:\Windows\System32\cfgmgr32.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
115-22:04:52.6132108 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
116-22:04:52.6132108 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
117-22:04:52.6132108 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
118-22:04:52.6132108 SDR Console.exe 18736 FILE_open C:\Windows\System32\vcruntime140_1.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
119-22:04:52.6132108 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\cfgmgr32.dll base:0x00007FFBCA860000 size:0x0004E000 0x00000000 [操作成功完成。 ]
120-22:04:52.6132108 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\HIDUSBRelays.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
121-22:04:52.6132108 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\winmm.dll base:0x00007FFBC4450000 size:0x00034000 0x00000000 [操作成功完成。 ]
122-22:04:52.6132108 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
123-22:04:52.6132108 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
124-22:04:52.6132108 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
125-22:04:52.6132108 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\FIRParksMcClellanDesign.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
126-22:04:52.6132108 SDR Console.exe 18736 EXEC_module_load D:\SDR-Radio.com (V3)\HIDUSBRelays.dll base:0x00007FFBC6590000 size:0x0000D000 0x00000000 [操作成功完成。 ]
127-22:04:52.6132108 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
128-22:04:52.6142559 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide access:0x00020019 0x00000000 [操作成功完成。 ]
129-22:04:52.6142559 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
130-22:04:52.6142559 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
131-22:04:52.6142559 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\HIDUSBRelays.dll access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
132-22:04:52.6142559 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\vcruntime140_1.dll base:0x00007FFBB3340000 size:0x0000C000 0x00000000 [操作成功完成。 ]
133-22:04:52.6142559 SDR Console.exe 18736 EXEC_module_load D:\SDR-Radio.com (V3)\FIRParksMcClellanDesign.dll base:0x00007FFBC6560000 size:0x0002E000 0x00000000 [操作成功完成。 ]
134-22:04:52.6142559 SDR Console.exe 18736 FILE_open C:\Windows\System32\vcruntime140.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
135-22:04:52.6142559 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide access:0x00020019 0x00000000 [操作成功完成。 ]
136-22:04:52.6142559 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\FIRParksMcClellanDesign.dll access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
137-22:04:52.6142559 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
138-22:04:52.6142559 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
139-22:04:52.6142559 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\FileExchange.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
140-22:04:52.6142559 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\setupapi.dll base:0x00007FFBCCC30000 size:0x00474000 0x00000000 [操作成功完成。 ]
141-22:04:52.6142559 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\vcruntime140.dll base:0x00007FFBAD2A0000 size:0x0001E000 0x00000000 [操作成功完成。 ]
142-22:04:52.6142559 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
143-22:04:52.6152543 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
144-22:04:52.6152543 SDR Console.exe 18736 FILE_open C:\Windows\System32\vcomp140.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
145-22:04:52.6152543 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
146-22:04:52.6152543 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
147-22:04:52.6152543 SDR Console.exe 18736 EXEC_module_load D:\SDR-Radio.com (V3)\FileExchange.dll base:0x00007FFBC6520000 size:0x00036000 0x00000000 [操作成功完成。 ]
148-22:04:52.6152543 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\vcomp140.dll base:0x00007FFBC64E0000 size:0x00030000 0x00000000 [操作成功完成。 ]
149-22:04:52.6152543 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide access:0x00020019 0x00000000 [操作成功完成。 ]
150-22:04:52.6152543 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide access:0x00020019 0x00000000 [操作成功完成。 ]
151-22:04:52.6152543 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\TMATE2_DLL.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
152-22:04:52.6152543 SDR Console.exe 18736 FILE_open C:\Windows\System32\wininet.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
153-22:04:52.6152543 SDR Console.exe 18736 FILE_open C:\Windows\System32\vcomp140.dll access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
154-22:04:52.6152543 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
155-22:04:52.6152543 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
156-22:04:52.6152543 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
157-22:04:52.6152543 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\FileExchange.dll access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
158-22:04:52.6162542 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
159-22:04:52.6162542 SDR Console.exe 18736 EXEC_module_load D:\SDR-Radio.com (V3)\TMATE2_DLL.dll base:0x00007FFBC63B0000 size:0x00008000 0x00000000 [操作成功完成。 ]
160-22:04:52.6162542 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide access:0x00020019 0x00000000 [操作成功完成。 ]
161-22:04:52.6162542 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\wininet.dll base:0x00007FFB9FFD0000 size:0x004FE000 0x00000000 [操作成功完成。 ]
162-22:04:52.6162542 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\TMATE2_DLL.dll access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
163-22:04:52.6162542 SDR Console.exe 18736 FILE_open C:\Windows\System32\d2d1.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
164-22:04:52.6172542 SDR Console.exe 18736 FILE_open C:\Windows\System32\powrprof.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
165-22:04:52.6172542 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
166-22:04:52.6172542 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\BugTrapU-x64.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
167-22:04:52.6172542 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
168-22:04:52.6172542 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
169-22:04:52.6172542 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
170-22:04:52.6172542 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\LimeSuite.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
171-22:04:52.6172542 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\d2d1.dll base:0x00007FFBC7950000 size:0x005EE000 0x00000000 [操作成功完成。 ]
172-22:04:52.6172542 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\powrprof.dll base:0x00007FFBCAB30000 size:0x0004D000 0x00000000 [操作成功完成。 ]
173-22:04:52.6172542 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
174-22:04:52.6172542 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
175-22:04:52.6172542 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
176-22:04:52.6172542 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
177-22:04:52.6172542 SDR Console.exe 18736 EXEC_module_load D:\SDR-Radio.com (V3)\BugTrapU-x64.dll base:0x0000000180000000 size:0x0005A000 0x00000000 [操作成功完成。 ]
178-22:04:52.6182529 SDR Console.exe 18736 EXEC_module_load D:\SDR-Radio.com (V3)\LimeSuite.dll base:0x00007FFBBDD00000 size:0x000B2000 0x00000000 [操作成功完成。 ]
179-22:04:52.6182529 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide access:0x00020019 0x00000000 [操作成功完成。 ]
180-22:04:52.6182529 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide access:0x00020019 0x00000000 [操作成功完成。 ]
181-22:04:52.6182529 SDR Console.exe 18736 FILE_open C:\Windows\System32\hid.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
182-22:04:52.6182529 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\BugTrapU-x64.dll access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
183-22:04:52.6182529 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
184-22:04:52.6182529 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
185-22:04:52.6182529 SDR Console.exe 18736 FILE_open D:\SDR-Radio.com (V3)\LimeSuite.dll access:0x00120089 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
186-22:04:52.6182529 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\hid.dll base:0x00007FFBC94C0000 size:0x0000E000 0x00000000 [操作成功完成。 ]
187-22:04:52.6182529 SDR Console.exe 18736 FILE_open C:\Windows\System32\msvcr100.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
188-22:04:52.6192541 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
189-22:04:52.6192541 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
190-22:04:52.6192541 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\msvcr100.dll base:0x000000005DC50000 size:0x000D2000 0x00000000 [操作成功完成。 ]
191-22:04:52.6192541 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\comdlg32.dll base:0x00007FFBCCB30000 size:0x000FF000 0x00000000 [操作成功完成。 ]
192-22:04:52.6192541 SDR Console.exe 18736 FILE_open C:\Windows\System32\msvcp120.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
193-22:04:52.6192541 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
194-22:04:52.6192541 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\SHCore.dll base:0x00007FFBCC420000 size:0x000FA000 0x00000000 [操作成功完成。 ]
195-22:04:52.6192541 SDR Console.exe 18736 FILE_open C:\Windows\System32\msvcr120.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
196-22:04:52.6192541 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
197-22:04:52.6192541 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
198-22:04:52.6192541 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
199-22:04:52.6192541 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\msvcp120.dll base:0x00007FFBBCEB0000 size:0x000A6000 0x00000000 [操作成功完成。 ]
200-22:04:52.6202722 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\msvcr120.dll base:0x00007FFBBCDC0000 size:0x000EF000 0x00000000 [操作成功完成。 ]
201-22:04:52.6288283 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options access:0x00000009 0x00000000 [操作成功完成。 ]
202-22:04:52.6298270 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\GRE_Initialize access:0x00020019 0x00000000 [操作成功完成。 ]
203-22:04:52.6298270 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Control Panel\Desktop access:0x00020019 0x00000000 [操作成功完成。 ]
204-22:04:52.6298270 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Compatibility32 access:0x00020019 0x00000000 [操作成功完成。 ]
205-22:04:52.6308255 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE access:0x02000000 0x00000000 [操作成功完成。 ]
206-22:04:52.6308255 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows access:0x00020019 0x00000000 [操作成功完成。 ]
207-22:04:52.6318391 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows\LoadAppInit_DLLs type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
208-22:04:52.6318391 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Ole access:0x02000000 0x00000000 [操作成功完成。 ]
209-22:04:52.6318391 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Ole access:0x02000000 0x00000000 [操作成功完成。 ]
210-22:04:52.6327886 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Ole access:0x02000000 0x00000000 [操作成功完成。 ]
211-22:04:52.6327886 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE access:0x02000000 0x00000000 [操作成功完成。 ]
212-22:04:52.6327886 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Ole access:0x02000000 0x00000000 [操作成功完成。 ]
213-22:04:52.6333618 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001 access:0x00020019 0x00000000 [操作成功完成。 ]
214-22:04:52.6333618 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001_Classes\Local Settings access:0x02000000 0x00000000 [操作成功完成。 ]
215-22:04:52.6333618 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001_Classes\Local Settings\Software\Microsoft access:0x02000000 0x00000000 [操作成功完成。 ]
216-22:04:52.6343870 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001 access:0x00020019 0x00000000 [操作成功完成。 ]
217-22:04:52.6343870 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Software\Microsoft\Windows NT\CurrentVersion\Windows access:0x00020019 0x00000000 [操作成功完成。 ]
218-22:04:52.6343870 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001 access:0x00020019 0x00000000 [操作成功完成。 ]
219-22:04:52.6343870 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001\Software\Microsoft\Windows NT\CurrentVersion\Windows access:0x00020019 0x00000000 [操作成功完成。 ]
220-22:04:52.6354300 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide access:0x00020019 0x00000000 [操作成功完成。 ]
221-22:04:52.6354300 SDR Console.exe 18736 FILE_open C:\Windows\WindowsShell.Manifest access:0x001200A9 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
222-22:04:52.6354300 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide access:0x00020019 0x00000000 [操作成功完成。 ]
223-22:04:52.6364303 SDR Console.exe 18736 FILE_open C:\Windows\System32\mfc140chs.dll access:0x001200A9 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
224-22:04:52.6384441 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\CustomLocale access:0x00020019 0x00000000 [操作成功完成。 ]
225-22:04:52.6384441 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\ExtendedLocale access:0x00020019 0x00000000 [操作成功完成。 ]
226-22:04:52.6384441 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\CustomLocale access:0x00020019 0x00000000 [操作成功完成。 ]
227-22:04:52.6384441 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\ExtendedLocale access:0x00020019 0x00000000 [操作成功完成。 ]
228-22:04:52.6384441 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\CustomLocale access:0x00020019 0x00000000 [操作成功完成。 ]
229-22:04:52.6384441 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\ExtendedLocale access:0x00020019 0x00000000 [操作成功完成。 ]
230-22:04:52.6393809 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\CustomLocale access:0x00020019 0x00000000 [操作成功完成。 ]
231-22:04:52.6393809 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Nls\ExtendedLocale access:0x00020019 0x00000000 [操作成功完成。 ]
232-22:04:52.6414283 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager access:0x00000009 0x00000000 [操作成功完成。 ]
233-22:04:52.6414283 SDR Console.exe 18736 REG_openkey HKEY_USERS\S-1-5-21-2997357444-1605343896-3593407233-1001 access:0x02000000 0x00000000 [操作成功完成。 ]
234-22:04:52.6414283 SDR Console.exe 18736 FILE_open C:\Windows\System32\umpdc.dll access:0x00100021 alloc_size:0 attrib:0x00000000 share_access:0x00000005 disposition:0x00000001 options:0x00000060 0x00000000 [操作成功完成。 ]
235-22:04:52.6414283 SDR Console.exe 18736 REG_openkey HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp access:0x00020019 0x00000000 [操作成功完成。 ]
236-22:04:52.6414283 SDR Console.exe 18736 REG_getval HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Srp\Gp\RuleCount type:0x00000000 datalen:0x00000000 data: 0x00000000 [操作成功完成。 ]
237-22:04:52.6414283 SDR Console.exe 18736 EXEC_module_load C:\Windows\System32\umpdc.dll base:0x00007FFBCAB10000 size:0x00013000 0x00000000 [操作成功完成。 ]
238-22:04:52.7592691 SDR Console.exe 18736 PROC_exec C:\Windows\System32\WerFault.exe target_pid:2108 cmdline:C:\Windows\system32\WerFault.exe -u -p 18736 -s 592 0x00000000 [操作成功完成。 ]
239-22:04:53.5127637 SDR Console.exe 18736 EXEC_destroy D:\SDR-Radio.com (V3)\SDR Console.exe parent_pid:12104 cmdline:"D:\SDR-Radio.com (V3)\SDR Console.exe" 0x00000000 [操作成功完成。 ]
I have no idea about it at all......
73,Haoxuan Ye
Posted: Sat Nov 09, 2024 11:33 am
Video card is WAY too old so Nvidia features will have to be disabled, if you ever get that far. It seems to die trying to load LimeSuite.dll which in turn tries to load a collection of Windows libraries. It dies in there.
1) Is your machine fully patched?
2) Are you running the latest stable SDRRadio release?
3) Have you messed with any of the files in the SDRRadio distribution?
4) It dies loading WerFault.exe, which reports errors. But that is not important. The real death is before that as the real death seems to involve SAFER system security rules which appear to cough up a furball, probably about LimeSuite.dll it's currently trying to load and setup.
I would disconnect any SDR hardware and try to run it again. If it loads and brings up the GUI, even the initial identity GUI popup, we will have discovered something important. This may be a problem with your machine and the LimeSuite file. Why it would deny running it, I've no idea.
I did some basic look ups. And now I may have an idea. The GTX 760 is not officially DirectX 12 compatible. SDRC makes extreme use of DirectX12 features for all its GUI, I believe. That might be your problem if the other troubleshooting shows no good results.
