Fixed spectrum zoom level
Posted: Sun Jan 19, 2025 10:12 pm
by MM0TWX
Thank you for reading this.
Amongst other thing, I use the software as panadapter, synched with my HF rig. The system works like a charm, but I find it annoying that any time I change band on the RTX, the amount of spectrum I see on the panadapter changes, and I have to re-set it to what I want.
Would it be possible to have the option to set a cetrain zoom level and have it stay like that until I want to change it, regardless of band changes?
Thank you so much.
73 Pete MM0TWX
Re: Fixed spectrum zoom level
Posted: Mon Jan 20, 2025 9:27 am
MM0TWX wrote: Sun Jan 19, 2025 10:12 pm Would it be possible to have the option to set a cetrain zoom level and have it stay like that until I want to change it, regardless of band changes?
73 Pete MM0TWX
Hi Pete
In top ribbon bar, on the "View" tab, in the section "Low, High, Zoom", untick the option "Auto-centre".
As far as I can see from another very long thread on here, I suggested this to someone else and I think it solved their issue with exactly the problem you are having.
