Unintelligible and very low audio
Posted: Tue Jan 28, 2025 5:42 pm
I have posted this message on the Kenwood 570 group on Facebook but I thought that I would do the same here as it may be a software rather than a hardware issue.
I'm attempting to set up a panadapter display using an RTL-SDR dongle and SDR Console. I tapped the IF signal at CN3 as described in a couple of YouTube videos. This tap connects to the dongle via an SMD connector. I've downloaded SDR Console and it appears to be running well. I set the software to accept an IF signal at 73.05 MHz. I'm running OmniRig for CAT control (it's working well).
However, I'm not getting any intelligible audio in the Console. I hear an extremely slight hint of a voice, but it is garbled and unintelligible. The software appears to recognize the signal, as there are spikes in the spectrum but no real audio. I do hear threshold static, which I can vary in volume by adjusting the volume levels in the software.
I've tested the dongle using an antenna and it receives well. I originally attempted to set it all up on a Windows 7 based computer, but when that didn't work, I did it all over again on a Windows 11 computer, thinking that it was a Win7 issue. But I got the same result on the new computer.
I systematically checked every adjustable parameter in the software that I could find (which took most of a day) but to no avail. I have toggled “Invert Spectrum” and have adjusted the bandwidth to a wider parameter on the advice of a fellow ham.
Any suggestions?
Any suggestions?
