Data File Playback, Incomplete Chained Set
Posted: Fri Feb 21, 2025 10:01 am
by pauldbnut
Sorry if this has been raised before.
I have a hard drive folder containing one set of chained recordings made by SDRC. They were found in an internet archive of HamSCI files.
The first 30 or so had been omitted, so the filename sequence begins <mainfilename> 036.wav.
The Data Playback file list shows all individual files, not the original single entry for a chain.
Any individual file from the list can be replayed just fine. Multi-select (separately or a range) is possible, but replay is not enabled for that.
My objective is to replay the whole "partial" set automatically.
Could the player be enhanced to allow that, please?
First attempts at workaround by renaming ...036.wav to ...000.wav (etc.) did not at first give the expected result.
For example, a sequence of 10 files showed as containing only 3. This may be related to physical sequence in a folder?
Paul
