External radio & tracking disables transmit audio
Posted: Wed Apr 23, 2025 2:46 am
I'm converting my ham radio computer usage to include SDRC as either the main receiver or as a panadapter. My Icom 7300, the "External Radio" will always be my transmitter. I've run across a weird thing. When running JTDX or WSJT, if "Tracking" is enabled, when I try to transmit, SDRC turns the transmit audio off a second or two later. Or the transmit audio never comes on at all. The radio remains in transmit mode until I or the JT program stops it. If I disable tracking, transmitting works properly. Receive works normally.
FlDigi behaves similarly, except that the External Radio has to be "powered off" in the SDRC External Radio pane.
In either case, if I quit SDRC, then transmit behaves normally. But SDRC and tracking is kind of useful for the non-JT digital modes. Everything was working correctly until I added SDRC's External Radio to the mix.
Here's my setup:
Win4Icom talks directly to the 7300 on COM7. It also provides two Com0Com serial port pairs that can communicate with other programs: COM 16-17 and COM 20-21.
Log4OM uses Omnirig v. 1.2, Rig #1, which is on COM 17.
JTDX and WSJT also use OmniRig Rig #1.
FlDigi doesn't support OmniRig. It uses RigCat, and talks on COM 21.
SCRC "External Radio" is also using OmniRig Rig #1.
All programs run "as administrator" so multiple programs can access OmniRig's multithreading capability.
All COM ports are currently running at 38400 baud.
I'm using CAT commands for PTT. But PTT works. It's the transmit audio that's giving me problems. And only when SDRC is using the "External Radio" function.
I also experimented with a setup that did *not* include Win4Icom. The same basic problem occurred. So the issue appears to be between Log4OM, SDRC and whatever digital program I'm running. Any ideas, anyone?
OmniRig Rig#1 configuration is attached. Rig #2 is the same, except that it talks directly to the 7300 on COM7, for running without Win4Icom.
--Peter, KD7MW
Here's my setup:
--Peter, KD7MW
