SDR Console / SDR TV Pluto IP Definitions
Posted: Wed Apr 23, 2025 6:24 pm
by Dave_G4EEV
Simon,
I have been eagerly awaiting the beta release of SDR TV and downloaded it today. My setup has the Pluto SDR connected on a separate network and is not directly connected via the USB port. The previous version of SDR Console was set up to work this way successfully. When installing SDR TV I also installed the latest version of SDR Console as instructed. I then created a definition for the Pluto manually, I included the DLL (plutoSDR), Name and IP address but left the other fields blank as I was unaware of their values. When I ran the configuration I got the error: "Connecting - failed to find USB connection with serial = 192.168.20.4" I checked that the firewall was open to local and network. Do I need the other information required in the definitions form? I must have managed this previously but cant remember how?
I moved the Pluto and installed it as a USB device and that was correctly detected and runs OK, but I would like to run it via the IP address from a different location. Thanks for all the hard work and for making SDR TV available.
73 Dave, G4EEV.
